[Z06] Which Cam?
Old May 10, 2014 | 11:56 AM
JMOFLA's Avatar
JMOFLA
Cruising
Default Which Cam?
Hello everyone. I am very new to corvettes I just bought my Zo6 about 2 weeks ago. Anyway the car already has corsa mufflers and a air intake on it. I just ordered some kooks 1 7/8 LT and a off road X pipe. I was wondering which cam has been popular I would like to break 400 WHP with a tune. I would like a cam that is friendly with a supercharger as I should be putting one on by the end of fall.
Old May 11, 2014 | 09:18 PM
DEnglish29's Avatar
DEnglish29
With the headers,x-pipe, exhaust, cold air intake and dyno tune you should be over 400 RWHP. With the listed above mine was 411.
Old May 11, 2014 | 09:29 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Unless youre doing the work yourself. Save money and do the cam swap at the same time as the supercharger.
Old May 14, 2014 | 02:29 PM
bmartin's Avatar
bmartin
Not calling you out or anything, but that seems quite suspect. Any track times with that setup?
I just put down 425/402 on a Brian Tooley Stage 2 227/234 .614 .576. Tuner said he left about 5-10hp on the table with 100% humidity.
With ARH LTs, Vararam, and Catted X pipe I put down 387/386 and ran 11.9s @ 118.
Either way, you should be over 400rwhp with any cam you choose.
Old May 14, 2014 | 04:08 PM
DEnglish29's Avatar
DEnglish29
Never has it at the strip with the current setup. I would post the dyno sheet if I could figure out how. However I will be more than happy to email it to you. Just pm me your email
Old May 14, 2014 | 05:25 PM
bmartin's Avatar
bmartin
I believe you that the dyno sheet reads 411, but I find it almost impossible that a header, cai, and tune ls6 is truly making 411 to the wheels. Trap speed would be a good indication. Some dynos are crazy high and some are stupid low. Typically 375-390rwhp is the accepted range for a simple bolt on C5Z.
Old May 14, 2014 | 05:27 PM
SunnydayDILYSI's Avatar
SunnydayDILYSI
I have AR headers, K&N CAI, Ti Muffelers, and a mild tune (didn't adjust the redline) and do 375 at the wheels. Quality motorsports is a great shop here in Dallas and did the headers, tune and dyno. They said 375 was towards the high end for those mods, but even a relatively small cam would put me over 400. The key for you will be to match the cam with your SC system. And remember, once you go SC road racing is pretty much off the table. Too much heat.
Old May 14, 2014 | 09:32 PM
JMOFLA's Avatar
JMOFLA
Cruising
Thanks for the Advice. I was checking out the MS3 and MS4 cams, you guys hear any good things about those?
Old May 15, 2014 | 11:57 AM
PRE-Z06's Avatar
PRE-Z06
Those are on the large end of the spectrum and wouldn't recommend going that big unless you've had previous experience with a cam that wasn't enough and willing to shift at 7k+ rpm to take full advantage of the power that it is going to make up there. I would pick something that has less overlap and drives better personally. Our VB (223/230 113) cam works great NA or with a blower in a 5.7 with LS6 heads and will be easier on valvesprings with boost, feel to call me with any questions.
Old May 16, 2014 | 07:30 AM
TXGS507's Avatar
TXGS507
Look at the cam Toque is running .... LGM G5X1E.... Awesome cam and he makes 470+ to the wheels.. Granted, he is running Heads,Intake as well... But he raves about the X1E... Oh and it is also blower friendly.
Old May 16, 2014 | 12:50 PM
danziger's Avatar
danziger
I would look at a 228-230ish cam profile that could work with a supercharger later (if needed). If the Z is primarily street driven, a milder cam with a good tune is IMHO the hot ticket.
Old May 17, 2014 | 02:38 AM
dagon138's Avatar
dagon138
A&A has some blower cams you may be interested in.
To Which Cam?
