Upgrading lights
Do HIDs get to hot for stock light housings?
I'm considering LED's for the fog lamps. There are some wildly bright Plasma and Cree LED fog lamp bulbs out there. You won't get HID power from the LED's but the color is nice and brighter than any halogen bulb.
For the reverse lamps, there is some new lens focused 5w Cree based LEDs. Hugely brighter than any halogen and even much brighter than the early SMD based LEDs
A already have a C5, or
B just considering a purchase?
If your answer is B: buy a C6 instead.
If your answer is A: good luck separating ACTUAL FACTS from personal opinions.
Now that I think about it, while being of absolutely no help in answering your original question, I'll just say "good luck separating ACTUAL FACTS from personal opinions."
( the preceding is entirely my opinion)
For a significant upgrade in headlight, we offer Projector based HID lighting with Bi-xenon (A projector that functions as low and high beam) optics. Both styles shown here will not only increase the intensity of light output with HID light source, but the projector will also spread out the light to cover nearly 10x the area as the factory reflector housing.
Factory low:
Bi-xenon ACA low:
Our pop up model:
http://shop.radioflyerinnovations.co...lights-015.htm
Our more exotic looking fixed model:
http://shop.radioflyerinnovations.co...lights-007.htm
Fog lights: - Unlike your headlights, the C5 fog lights are perfectly suitable for a simple HID retrofit. The projector housing provides excellent optics for focusing the HID pattern. You can purchase our HID fog light kit here:
http://shop.radioflyerinnovations.co...ht-Kit-004.htm
Reverse lights - The Reverse lights are an area where an upgrade to the bulb will provide significant output, but an upgrade to the housing as well will provide an even better output. Our Adjure Reverse light housing with our Cree 80w LED bulbs provide nearly as much output (1600 lumens) as your factory headlights
http://shop.radioflyerinnovations.co...rvette-013.htm
Let me know if you have any questions.
If you want BETTER lights, put HIDs in projector housing.
I tried both, and after going with projectors I would NEVER go back to stock housings.
Do not melt the housings and provide a lot more light.
