Use my pucks at the local garage when they have nice heavy rubber pads on each of the four arms of their lift? Seems like it would accomplish the same net results, but I'm asking for the voice of experience to tell me what best. I appreciate it...
Thanx
Bob
Just make sure that they know about the problem with vettes and know how to properly lift it without crushing the rocker panel. If their rubber pads are not thick enough or positioned right , it will damage the lower body.
I would still use your jacking pucks. The jacking pucks are designed to keep any lift pads from making contact with the rocker panel. If their lift pads contact the panels, then there is always the chance for some damage.
After taking a good bit of time to put mine on a lift to do the brakes, I decided to get the pucks with the eyebolt in them to take the positioning guesswork out.
simple rule in my opinion on this is that you are always better off safe than sorry. unless you can swear that the lift operator can be trusted 100% to be professional and have complete command of the equipment you are always taking something of a chance no matter how good he has been in the past. easier than having to go through body repair.
You've got the pucks and it only takes a couple of minutes to insert them, so why take the unnecessary risk of damaging your vehicle? It's seems like a no-brainer to me.
On a side note, did you know that the coups are supposed to have the targa top unlatched before lifting? Its supposed to stop from damaging it or the glass because of flex. I lift mine all the time without doing it and so far so good.. but I learned that at a shop recently.
Hadn't heard that one but one shop told me to pop the hood first before lifting to destress it somehow.....
The biggest advantage is that they give a nice target for the lift pads.
At my friends shop, the only lift I can fit on is the side by side, which just clears the pucks....All of his 4 post lifts are heavy duty and are too high to clear and without some serious ramping the alignment rack won't work either.
The first time I took the Corvette to my local mechanic, I gave him the pucks and he used them to lift the car. After that he said he was going to make himself a set.
The rubber pads on the lift won't keep the weight of the car from sitting on your rocker panel molded pieces that roll under and are part of the body panels. You need the pucks to keep the weight on the frame and off the panels. Use the pucks or ignore the cracks.
Instead of asking 'do I really have to', maybe you should be just insisting that the mechanic or shop about to work on your car 'really has to' use the pucks.
And I think, you should go to a different shop, if they don't agree. Actually, if you have to make sure, or insist that a shop use lift pucks on a Corvette; you are in the wrong shop, and should leave....
I have read that repairing the rocker arm damage can be very very expensive. Who will you blame for that, if you don't insist on using the lift pucks?
