fuel pressure issue?
Old Jun 25, 2014 | 05:28 AM
didntdoit11's Avatar
didntdoit11
St. Jude Donor '12
Default fuel pressure issue?
I have heads and cam car (42lb injectors)(in time will be running nitrous) I installed a welbro pump and a racetronix hot wire kit now my fuel pressure is almost at 70lbs at idle, is this normal ? what should I do
Old Jun 25, 2014 | 10:01 AM
dadaroo's Avatar
dadaroo
You don't know what the pump is supposed to deliver? Call me weird, but maybe looking at the pump specs or talking with the manufacturer might be in order.
Old Jun 25, 2014 | 10:05 AM
3boystoys's Avatar
3boystoys
YIKES, I think your WAY OVER PRESSURE.
Old Jun 25, 2014 | 12:19 PM
didntdoit11
St. Jude Donor '12
its c5 pump and hot wire kit from racetronix. sorry misworded it...below is the kit I received
C56 Fuel Pump Kit
RFPK-008 - 2003+ C5 & C6 Corvette
Old Jun 25, 2014 | 12:36 PM
StingrayRebel's Avatar
StingrayRebel
I have 65psi cold and 60psi when heat soaked with a walbro pump and harness... I would be more worried if it was extremely low
To fuel pressure issue?
