...... if the security light stayed on the car wouldn't run, sounds like that is not the case here. I'm not sure what the value of the vats system is if it lets the car run with the wrong key.
I think if the car runs its a more complex issue.
When the BCM sends the signal to the key it looks for the resistor value programmed into the BCM. If it gets a bad value (wrong key) the security light stays on and the start is inhibited.
If it gets the correct value the theft deterrent relay is energized, the column lock is released and the PCM is told to enable fuel delivery. Then the car runs.
If and intermittent fault then occurs (say the key loses contact because it or the barrel is worn) a DTC would be set during the "cycle". The car wouldn't stop for safety reasons.
The book shows shorts in the circuit, poor connections at the BCM or gnition switch ignition lock contacts or resistor pellets dirty or loose as reasons for intermittent faults.
For that reason if the OP is getting the car going I suspect something is worn.
I also understood that if the security light stayed on the car wouldn't run, sounds like that is not the case here. I'm not sure what the value of the vats system is if it lets the car run with the wrong key.
It doesn't. But a key can be "wrong" intermittently if the resistor isn't making solid contact. And I doubt it checks the key after the car is running.
Read the first post, it says started the car and the security light stayed on. If it doesn't read the key after the car starts, why did the security light not go off when it allowed the car to start? He doesn't say he tried to start the car and then retried and it started and the light stayed on. Something more than a resistor value is in play here.
We already covered this. Tell you what, slog through that section in the FSM yourself and report back on how you think it works.
And note that we only have one code reported out of what sounded like a lengthy list.
I have a very similar thing happening and been ignoring it for a while, probably not wise My car starts and runs fine but occasionally when going over a rough patch of pavement or hard banking in some turns the security light will come on and stay on till I stop and restart the car. My key fits pretty loose in the ignition so I attribute this condition to a worn out cylinder and loss of pellet contact when key is jarred during driving. This would also suggest that the system constantly reads the key resistor value and goes into security mode anytime it is interrupted, even after the car is started. It would also suggest the car will remain running when security circuit is tripped, safety would be a good reason. It would be wise on my part to replace the cylinder.
