Alignment Question
Old Aug 25, 2014 | 03:31 PM
wcsinx's Avatar
wcsinx
Originally Posted by mrr23
Or their machine is out of calibration. A sensor could have slipped out of place on the wheel. Or the guy has a vision problem?
All possible, but the fact that they put it back on the rack and pointed to the track arrow in an attempt to vindicate themselves shows a severe misunderstanding of how alignments work. I mean I could make a car track dead ahead with the steering wheel 180° out if I really wanted to.
Old Aug 25, 2014 | 06:54 PM
donald4972's Avatar
donald4972
St. Jude Donor '14-'15
Originally Posted by Dave-A
Keep taking it back until it is correct. Does not matter what the computer screen shows, it should be perfect on the road or they did not do it correctly.
I agree!!! My alignment shop said, after alignment, to drive it for a day, and if it did not seem perfect, including steering wheel alignment, to bring it back. It would be a simple adjustment for them to put it where I wanted it.
Take yours back, or get a different shop who knows what they are doing.
Don
Old Aug 25, 2014 | 07:52 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Originally Posted by wcsinx
This
Whoever did your alignment is a moron. Even if the track is set correctly, it doesn't mean your steering wheel is aligned. They most likely performed toe adjustments without centering and securing the steering wheel first.
Don
Remember, this was a dealership and I had a service coupon. That was MY mistake.
I brought it to another shop back when I originally lowered the car and installed my first set of aftermarket wheels and non run-flats and the car drove fine. Since this dealership is over 30 miles away, I will go back to the original shop that performed the original alignment service correctly after I complete my brake upgrade project.
The dealership repositioned the steering wheel and it's not as bad as what it was, however after three attempts, I have no faith they got it right. Since I basically ended up paying for only the oil change, lesson learned and I will never step foot in their service department again.
Old Aug 25, 2014 | 08:56 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
and i agree there. the biggest mistake the tech made was by not driving it afterwards. just because the machine says it's straight doesn't mean it was, if the machine is out of calibration.
Old Aug 25, 2014 | 09:04 PM
racebum's Avatar
racebum
This
that's what this thread sounds like to me. steering wasn't centered
because a car driving straight means nothing, absolutely nothing, if a car doesn't drive straight the alignment is beyond f'lked
i've had cars that were really off, like 1/4" off and they drove straight
Old Aug 26, 2014 | 11:35 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
Decided to put some wider tires on the rear and recheck the alignment. This is what it should look like with a straight steering wheel. As a good friend of mine says. That's money right there.
All dead on factory specs with about 0.30 higher caster on the right.
Old Aug 26, 2014 | 12:24 PM
Ron C!'s Avatar
Ron C!
Bring your car over to Orlando and let mrr23 align it. He did my coupe and my trip to work got shorter. I never realized how much the car wondered around until Robert worked his magic.
Old Aug 26, 2014 | 12:39 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Thanks ron.
MSG C5's Avatar
MSG C5
I will probably do that. I'm working on a brake upgrade next and after I finish that, I will take an Orlando day trip (stop in for some Chicago pizza at Giordano's) and get the alignment performed correctly!
Old Aug 26, 2014 | 01:52 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
See you when you get here
Old Aug 26, 2014 | 10:32 PM
MSG C5's Avatar
MSG C5
Thanks. I will reach out when ready. Another "coincidence" is that I have a hyper flash with my passenger turn signal ever since their alignment attempt. I wonder if they knocked my hyper flash harness when working on the alignment underneath the knee bolster. Might be completely unrelated.
All the LEDs are still working.
Old Aug 27, 2014 | 06:58 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
Should be unrelated
