Mechcanic help
Old Aug 30, 2014 | 01:03 PM
onevettenut's Avatar
onevettenut
Default Mechcanic help
looking for a Vette mechanic that is good with ABS system in the Rockford IL area
Thanks for help
Old Aug 30, 2014 | 02:13 PM
3boystoys's Avatar
3boystoys
What's the problem? I have an 01 too and all the services manuals for it as well as a scanner. I'm in the western burbs of Chicago.
Old Aug 30, 2014 | 03:23 PM
onevettenut
The codes I have are C 1228 and C 1235 both are for a R/R speed sensor. I have changed the sensor, checked connector, also checked wiring from EBCM connector thru sensor and back with ohm meter. All checked good. I then sent ECBM out and had it rebuilt. Put everything back together and cleared codes. Test drove and in 3to 4 miles warning lights are back on and same codes. Need to have some new ideas.
Old Aug 30, 2014 | 03:50 PM
3boystoys's Avatar
3boystoys
Change tires or wheels lately?
Old Aug 30, 2014 | 03:56 PM
onevettenut
Tires and wheels have been in use for 3 years...245X45X17 frt....295X35X18 rears.
To Mechcanic help
