Mechanic help
Old Aug 30, 2014 | 01:07 PM
onevettenut's Avatar
onevettenut
Default Mechanic help
looking for a Vette mechanic that is good with ABS system
in the Rockford IL area
Old Aug 30, 2014 | 01:35 PM
Phanni's Avatar
Phanni
What kind of problem are you having and what year is your car?
There is a wealth of knowledge here on the forum.
Old Aug 30, 2014 | 03:21 PM
onevettenut
The codes I have are C 1228 and C 1235 both are for a R/R speed sensor. I have changed the sensor, checked connector, also checked wiring from EBCM connector thru sensor and back with ohm meter. All checked good. I then sent ECBM out and had it rebuilt. Put everything back together and cleared codes. Test drove and in 3to 4 miles warning lights are back on and same codes. Need to have some new ideas.
To Mechanic help
