mrr23 mod thread
St. Jude Donor '15
mrr23 mod thread
thought i would condense my mod posts into one area. i will either post some pics or links to the original threads.
here is how the car looked when i first bought it in january 2014
mods on car as received
car has k/n filter
bbk headers
billy boat exhaust
corbeau racing seats
Simpson 5 point harnesses
HID Headlights
Hardbar
Black Z06 wheels
car has k/n filter
bbk headers
billy boat exhaust
HID Headlights
Hardbar
Black Z06 wheels
St. Jude Donor '15
next up was the task of repairing the hood and painting it and the rear hatch
https://www.corvetteforum.com/forums...nting-car.html
added hood stripes from www.vettestripes.com
St. Jude Donor '15
did some engine maintenance by changing the valve springs and adding 1.7 yella terra rockers.
https://www.corvetteforum.com/forums...r-install.html
St. Jude Donor '15
then got bored and swapped my wheels to C6 Z06 wheels
https://www.corvetteforum.com/forums...with-pics.html
St. Jude Donor '15
went to the track in july 2014 to see what it could do
https://www.corvetteforum.com/forums...k-results.html
2000 A4
K/N FIPK
BBK headers
Hi flow cats
B&B x-pipe
stock mufflers with bypass
2.73 gears
305/35-18 toyo R888
my guess was 13.30 ish
made 6 runs
Run #1
60'.... 2.179
330'.... 5.944
1/8.... 8.952
mph.... 82.60
1000'.... 11.487
1/4.... 13.611
mph.... 105.60
Run #2
60'.... 2.084
330'.... 5.849
1/8.... 8.847
mph.... 82.73
1000'.... 11.375
1/4.... 13.496
mph.... 105.60
Run #3
60'.... 2.059
330'.... 5.787
1/8.... 8.767
mph.... 83.26
1000'.... 11.286
1/4.... 13.401
mph.... 106.00
Run #4
60'.... 2.251
330'.... 5.962
1/8.... 8.926
mph.... 83.82
1000'.... 11.428
1/4.... 13.532
mph.... 106.54
Run #5
60'.... 2.130
330'.... 5.832
1/8.... 8.798
mph.... 83.79
1000'.... 11.302
1/4.... 13.410
mph.... 106.24
Run #6
60'.... 2.038
330'.... 5.720
1/8.... 8.675
mph.... 83.94
1000'.... 11.173
1/4.... 13.279
mph.... 106.34
couldn't foot brake it over 1200 rpm due to from what i've read torque management kicking in. this is with traction control turned off. that's no fun. could probably crack a 12 if i could launch harder. i never needed to burn out the tires because of the 2.73 gears and tires.
2000 A4
K/N FIPK
BBK headers
Hi flow cats
B&B x-pipe
2.73 gears
305/35-18 toyo R888
made 6 runs
Run #1
60'.... 2.179
330'.... 5.944
1/8.... 8.952
mph.... 82.60
1000'.... 11.487
1/4.... 13.611
mph.... 105.60
Run #2
60'.... 2.084
330'.... 5.849
1/8.... 8.847
mph.... 82.73
1000'.... 11.375
1/4.... 13.496
mph.... 105.60
Run #3
60'.... 2.059
330'.... 5.787
1/8.... 8.767
mph.... 83.26
1000'.... 11.286
1/4.... 13.401
mph.... 106.00
Run #4
60'.... 2.251
330'.... 5.962
1/8.... 8.926
mph.... 83.82
1000'.... 11.428
1/4.... 13.532
mph.... 106.54
Run #5
60'.... 2.130
330'.... 5.832
1/8.... 8.798
mph.... 83.79
1000'.... 11.302
1/4.... 13.410
mph.... 106.24
Run #6
60'.... 2.038
330'.... 5.720
1/8.... 8.675
mph.... 83.94
1000'.... 11.173
1/4.... 13.279
mph.... 106.34
mrr23 (09-10-2015)
mrr23 (09-10-2015)
Received 19,305 Likes
'20-'21-'22-'23-'24
Lots of nice mods you've done.
mrr23 (09-10-2015)
mrr23 (09-10-2015)
Coorvette (05-09-2016)
St. Jude Donor '15
Did the dim hvac fix today. Much better
write up here
https://www.corvetteforum.com/forums...splay-fix.html
write up here
St. Jude Donor '15
went to the dyno at www.nlperformance.com next level performance
K/n fipk
Bbk headers
Hi flow cats
B&B x-pipe
2.73 gears
Auto
Stock tune
https://www.corvetteforum.com/forums...post1587892065
K/n fipk
Bbk headers
Hi flow cats
B&B x-pipe
2.73 gears
Auto
Stock tune
