Idling issue - question
Old Sep 30, 2014 | 11:23 AM
enoniam's Avatar
enoniam
Originally Posted by Sinister-one
The car runs great through the gears and even under hard acceleration.
As a matter of fact after I drop the hammer on it, it kind of clears ups for a good 15 minutes or so....
Maybe time to change the O2 sensors???
Old Sep 30, 2014 | 11:59 AM
Sinister-one's Avatar
Sinister-one
I was thinking about that this morning on the way into work....
Can an auto parts store pull the codes ??
Old Oct 1, 2014 | 11:26 AM
Sinister-one
Did a little bit more cleaning of the throttle body and it seems to clearing up the idling issue.... but not quite fixed yet.
Old Oct 1, 2014 | 01:04 PM
66dts-v's Avatar
66dts-v
You can pull the codes yourself through the DIC.
Old Oct 1, 2014 | 10:13 PM
Sinister-one
doing that in a few minutes....
Old Oct 1, 2014 | 11:06 PM
Sinister-one
Okay, these are my codes....
PCM:
P0171 H C - Fuel Trim System Lean Bank 1
P0174 H C - Fuel Trim System Lean Bank 2
P0463 H - Fuel Level Sensor 1 Circuit High Voltage
Someone PLEASE tell me what this means....
Old Oct 1, 2014 | 11:22 PM
Choreo's Avatar
Choreo
PCM:
Might help...
https://repairpal.com/OBD-II-Code-P0171-and-P0174
Old Oct 1, 2014 | 11:37 PM
Sinister-one
Originally Posted by Choreo
Okay so from what I read, the culprit could be my maf sensor is going bad....
Old Oct 2, 2014 | 12:08 AM
Choreo's Avatar
Choreo
A possibility.
Both times I had a similar problem, it was the throttle body around where the butterfly closes that got gummed up - even more likely if you are running an aftermarket oil-impregnated filter. However, I never got any codes.
Old Oct 2, 2014 | 12:14 AM
Sinister-one
A possibility.
Without taking off the TB... I've already cleaned it. Looks like I'll have to take it off and clean the heck out of it !!
And yeah, I have an aftermarket oil-impregnated filter - K&N with my Vararam.
Maybe I should use a different filter as well.
Old Oct 2, 2014 | 11:39 AM
Sinister-one
I have a 90mm spare MAF... swapping it out tonight and lets see what happens.
Old Oct 7, 2014 | 01:39 PM
Sinister-one
Looks like I'm buying a replacement MAF....
Old Oct 7, 2014 | 07:50 PM
  #33
Z06ufgrad2002's Avatar
Z06ufgrad2002
Are you using an aftermarket oiled air cleaner?
Did you try cleaning your existing MAF ?
Old Oct 7, 2014 | 10:13 PM
  #34
El original's Avatar
El original
I have had same problem, low idle speed. Found extremely dirty air filter to be the culprit. Still took half and hour to get to proper idle speed after changing it out. I still think you have issues with your after market air filter.
Old Oct 8, 2014 | 09:43 AM
  #35
Sinister-one
Throttle body was cleaned, MAF was cleaned and my K&N air filter was cleaned about 5 months ago.
My K&N air filter was cleaned about 5 months ago.
I guess I could take everything apart this evening and check the air filter again......
Old Oct 10, 2014 | 01:31 PM
  #36
Sinister-one
Replacement MAF arrives today. AND I'm off today ! Time to work on and clean up my baby !!
Old Oct 10, 2014 | 07:02 PM
  #37
Sinister-one
Well hell !!!
Looks like I found my problem......
This small piece of vacuum hose has a nice hole in it !!
And it goes right here...
Would anyone know where I can get a replacement OR can I just use a piece of vacuum hose cut to size ?
To Idling issue - question
Old Oct 10, 2014 | 07:09 PM
  #38
73Corvette's Avatar
73Corvette
Well hell !!!
Good job man.....I would think just a nice tight fitting piece of vacum hose will fix you up.....
Old Oct 10, 2014 | 07:19 PM
  #39
Sinister-one
Well heck.... time to take the piece over to a parts store and match it up !
Old Oct 11, 2014 | 02:34 PM
  #40
Catman58's Avatar
Catman58
Doesn't it make you feel good when you find the root cause of the problem. HAPPY HAPPY HAPPY
