Idling issue - question
Old Oct 11, 2014 | 04:36 PM
  #41
eddie gold's Avatar
eddie gold
Originally Posted by Sinister-one
Okay so for the past week I've noticed that my FRC has been dropping the idle down from 700-ish to under 500 when I come to a stop. Almost as if it wants to die out and then comes back.
Once I get going again and come to the next stop it does the same thing over again. This is getting pretty annoying. Should i have it checked out at my local dealership ? ( I have a buddy that works there)
OR is there something I can do to fix this ?
Car has new plugs and wires. I cleaned the K&N filter about 3 months ago.
And ideas ??
Had the exact problem with my C4 tried everything ended up going to a dealer. They got in right on the first try. ICA valve Hope this helps
Old Oct 12, 2014 | 08:19 PM
  #42
Sinister-one's Avatar
Sinister-one
well heck..... replaced the busted vacuum hose, took the car for a spin and it's still doing the same thing.....
What the heck else can still be wrong with this ???
Old Oct 13, 2014 | 10:05 AM
  #43
dezcapt51's Avatar
dezcapt51
Did you replace the pcv when u replaced that vacuum hose ? I had the same problem busted hose and clogged pvc .
Old Oct 13, 2014 | 11:27 AM
  #44
Sinister-one
Okay gound thr pcv valve... hidden inside a plastic housing.
HOW do I remove it from that housing ??
Old Oct 15, 2014 | 12:09 AM
  #45
Sinister-one
Problem solved !!
Thanks for all the help fellow members !
Old Oct 15, 2014 | 12:58 AM
  #46
UM Rebel's Avatar
UM Rebel
Originally Posted by c31980
dont forget to check pcv ..
What year is it. 2004's don't have pcv. They have fixed orifice system. At least my '04 does. Probably should not speak for all.
Old Oct 15, 2014 | 02:28 AM
  #47
Choreo's Avatar
Choreo
His profile shows that he has a 2000. I have a 2001 and it has a PCV Valve (same as you can see in his photo in post #37). I have changed mine twice, but never had any issues with mine - just maintenance.
Problem solved !!
So your problem was a bad PCV Valve?
Old Oct 15, 2014 | 12:23 PM
  #48
Sinister-one
Nope..... had a hole in the vacuum hose from the pcv valve to the intake, (photo in post #37). Replaced the hose and and the idling problem was pretty much gone. But it continued for a day of so, not as bad. I replaced the pcv valve as suggested by other members and now she's back to normal.
I'm guessing the pcv valve was partially bad due to the hole in the vacuum hose.
