was making a run today got her up to 175 when the drivers window popped out it come out of its track, i slowed down right away all i had to do was roll window down then back up to reseat it , its a 2003 convt and was wondering if anyone has encountered this while going that fast , I've had her to 160 several times but once i hit 175 i thought i lost the window , thx ,
Hopefully this was at a track and not on a public highway.
Not sure if the vert has the same blow out clips on the top, but here's a file on a coupe. You might look to see if it is something that can be done on a vert.
I've had mine up to 165 and left the windows up, less drag and noise. Hahahaha. But no! Problems. But it's not a Vert. It's a Z06. If that makes any difference!
Reason: Change word.
That is right around the speed where a friend's C6 convertible cloth roof separated off of the frame!!
And the car was only a year old, so the repair was cover under the factory warranty.
And yes it happened at a sanctioned high speed event.
