How to exercise the ABS pump?
Old Nov 15, 2014 | 04:05 PM
mctwist77's Avatar
mctwist77
Default How to exercise the ABS pump?
So I'm getting the 1243 code for a stalled abs pump. I want to hardwire it to the battery to excerise it. Does anyone have photos of how to do this?
Old Nov 15, 2014 | 05:09 PM
Black 02's Avatar
Black 02
I believe you can use a tech 2 to do this. Can't say I would recommend hooking it up directly to a battery.
Old Nov 15, 2014 | 05:12 PM
mctwist77's Avatar
mctwist77
Yeah dealer wants $125 to do it. I know people have done it. I just want to make sure I put the wires in the right places
Old Nov 15, 2014 | 05:15 PM
JR-01's Avatar
JR-01
Jack up the rear end, start it and get it up to 10 mph.
Old Nov 15, 2014 | 05:45 PM
Lee DeRaud's Avatar
Lee DeRaud
What, they don't have any wet parking lots where you live?!?
Old Nov 16, 2014 | 04:15 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
If not, try a flat, grassy area....
Old Nov 16, 2014 | 05:37 PM
88redconvert's Avatar
88redconvert
I got the same code along with ABS and TC warning lights on mine. Jacked the rear up, started the car and pulled it into 2nd gear (automatic). Let it idle up to about 8-10 mph. The pump came on, the lights went out and never came on again. Worked for me. Hope this helps.
Old Nov 17, 2014 | 06:21 AM
Cybermind's Avatar
Cybermind
Using a Tech2 is the best way. But this is the way I did it prior to getting my Tech2:
https://www.corvetteforum.com/forums...s-weekend.html
Old Nov 17, 2014 | 01:01 PM
voda1's Avatar
voda1
Here are a couple of links:
https://www.corvetteforum.com/forums...surements.html
https://www.corvetteforum.com/forums...post1572207534
Old Nov 19, 2014 | 09:57 PM
johnson-rod's Avatar
johnson-rod
Drive to work the morning after a soaking rainstorm in 18 degree weather.
That'll exercise the pump.
If you can get the driver's door open that is....
Old Nov 20, 2014 | 06:49 AM
Cybermind's Avatar
Cybermind
But there are alot of members who do not drive in the rain. That is the main issue. I'll admit, I'm one of them. Not because I don't want to. I don't need to because my C5 is just a weekend toy, like many on this forum.
Old Nov 20, 2014 | 06:28 PM
Caveboy's Avatar
Caveboy
Does any one have a step by step installation to do this on a tech 2?
To How to exercise the ABS pump?
