Headlamp Bulb Replacement/Upgrade
you opened a post from 2015, so the current state of the art might have changed. One thing missing from a lot of these conversations is legality. While the law is behind the times, the intent of the laws, safety is still up to date.. A lot of aftermarket set ups use motorcycle lights. Which are expected to turn with the vehicle, so don't throw as wide of a beam as a car headlight, which might be useful to know, depending on your terrain, when forming a buying decision.
I also see posts where guys validate their E bay DIY lighting choices with the statement they are not blinding people because they get no headlight flashes the other way. Not good enough, and negates the present day reality of few people bother with such a signal at the closing speeds seen today, if they ever even knew there were such a signal.
If they are too careless to get out of their car and check the light pattern, I certainly would not be taking their safety advice. The reflector and the light source are required to match, the original design, otherwise the beam is not focused correctly.
Spend a little more and get some ACA projector clones for a cheap bump up in output (black housings may also be available from forum vendors)
https://www.ebay.com/itm/15475049032...UAAOSwlS9huhCV
