c5 corvette hot
I mentioned the same issue to the guys working on my car, they are going to start with checking for debris. I do not run as hot but still hotter than I think it should.
It's really hard to tell if the radiator is clean just by looking at it casually, mine looked clean but, when I tried blowing what little tiny bit of crap was in it out ( I made a special tool to reach between the coils to blow them clean) it wouldn't even blow thru it...it was completely plugged off, but only between the fins. I just took it out and took the water hose to it and cleaned it. NO more overheating.
Irreverent?? you just told me you can see yours ( argumentative ).. and I told you, you can NOT .. here is the problem .. what you are looking at is NOT the radiator.. you wonder why I'm so irreverent??? it because you are trying to tell me something that just isn't true.. and I have to further explain.. I explained it in a nice way , told you the radiator is behind the condenser... I was nice and you did not believe and said you can see yours.. I took the time to explain why you could see it and you just blew it off in an assumption that your condenser was your radiator.. when you get comebacks like this , for 14 years, you should not wonder why I can get so pissy...
I didn't say you could...
"Irreverent??"
what does that even mean? I didn't say anything about you being irreverent.
"I took the time to explain why you could see it and you just blew it off in an assumption that your condenser was your radiator"
I know the difference between the radiator and condenser, why are you so condescending?
" you should not wonder why I can get so pissy..."
I wouldn't waste my time wondering why you're pissy, it's not my problem
at the very front 0f the car is the AC condenser, 1 1/2 inches "behind" it sits the radiator, and hooked directly to the radiator " behind it is the dual electric fan unit.
<-------- Front of car condenser| radiator | fans
You can not blow out the radiator from the back while mounted in the car because the fan unit covers the rear of the radiator completely.. in front of the radiator is the condenser which completely covers the radiator allowing no access to it... the only way to blow out the radiator from the back is to remove it.
air flows through the condenser to create heat transfer for the AC unit.. if the Condenser is block and air will not flow through it and reach the radiator behind it.. both the condenser and radiator have to be cleaned because they both draw in clay sand, leaves paper grass etc..
here is a photo of the radiator with the fans attached...
most of the debris that gets trapped in the radiator is at the top.. where the fan mount covers it. So there is no access from the rear to blow it out from the back, unless you remove the radiator itself.. removing the fans is not a good option.. because of the clearance too close to the block.. but the radiator comes straight out the top.. once you pull out the radiator.. the condenser which sits in front of it can easily be cleaned from the back side once the radiator is remove from the radiator mount.
here is a photo of the condenser which sits directly infront of the radiator and is the only thing visable from under the car where the air dam directs air and into the condenser.. the radiator is sandwiched between the condenser in the front and the fans in the rear.
Unless you agree, you have to remove the radiator to clean it.. you can not even inspect the radiator while it in the car..
this is the condenser of a C5 Corvette its the one that gets all the leaves and the one most people think is the radiator.. BUT ITS NOT
