[Z06] Valve spring replacement mileage?
Old Mar 13, 2015 | 12:23 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Default Valve spring replacement mileage?
Yes, I did a search. Didn't find anything other than people replace valve springs for PM.
Wife has an '05 CTS-V (with an LS6) that she DD's to work with. I drive it occasionally an that is the only time the engine goes over 3500 RPM. Car has 125k on it. What say you?
Old Mar 13, 2015 | 01:16 AM
rjwz28's Avatar
rjwz28
People mostly replace valvesprings on here because they have years with high rates of failure (02-03) or because they have a high-lift cam... Since you have neither, that's your call
If it makes you feel safer, go for it
Old Mar 14, 2015 | 04:37 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
My 2002 Z had low mileage when I bought it but it was in the troublesome time frame so I replaced the valve springs for peace of mind.
Old Mar 14, 2015 | 10:07 AM
Brock63's Avatar
Brock63
Replaced mine as PM....20k miles with the stock blue GM valve springs which are almost impossible to find now. If it had taken just a bit longer I would have gone with Comp springs as recommended by Lingenfelter.
Old Mar 14, 2015 | 10:27 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Thanks for the replies. I wasn't aware that there was a "problem timeframe" for those. I'd guess that since ours is an '05 it is after that time frame.
Old Mar 14, 2015 | 04:35 PM
Freshbake's Avatar
Freshbake
I've got an 02 and after reading all the horror stories on the valvespring failures, I replaced them immediately at 30k miles. The stockers looked fine but I didn't want to take any chances.
Old Mar 14, 2015 | 05:05 PM
danieloneil01's Avatar
danieloneil01
If you're bored then go for it. I went with BTR springs that are stock replacements.
Old Mar 14, 2015 | 06:02 PM
LT1driver's Avatar
LT1driver
mine replaced at 16k if I remember correct......74k on it now. personally would not go with anything from comp cams, just my opinion.
Old Mar 15, 2015 | 09:22 AM
Dan H.'s Avatar
Dan H.
St. Jude Donor '17
My vin is right in the middle of the bad range. Replaced them at 17k miles. My engine is stock, but I track my car.
Old Mar 16, 2015 | 12:24 AM
ZeeOSix's Avatar
ZeeOSix
Read this thread ... it's a sticky thread at the top of this forum. A 2005 LS6 should be very low risk as GM changed the valve springs around 2004 I believe.
https://www.corvetteforum.com/forums...-failures.html
Old Mar 16, 2015 | 11:00 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
^Perfect. Thank you!
To Valve spring replacement mileage?
