weird problems with electrical **HELP**
Old May 8, 2015 | 08:28 PM
~STOLEN~'s Avatar
~STOLEN~
Default weird problems with electrical **HELP**
tried to put in some led reverse lights.....they didn't work at all..bought silverstar lights and they work, but only when in reverse. I have approach ON.
now, recently my drls stopped working.
also, I have euro tails and when I hit the brake the signals come on with the brake light.
both sides work when only the signal is used.....hit the brake and everything comes on
please help me
Old May 8, 2015 | 08:35 PM
UM Rebel's Avatar
UM Rebel
I would start by putting all back to conventional lighting. What works and doesn't work then. I gave up on LED lighting and am back to stock. Everything works now
Old May 8, 2015 | 08:43 PM
~STOLEN~'s Avatar
~STOLEN~
LOL
they reverse lights where the first and ONLY lights that I tried. so only thing I have is "cool blue" replacement bulbs in the reverse lights. so I dunno
from what I understand, everyone wants their drls off, but I don't mind them cause they are just what I expect to see when I see a vette coming at me.
BUT, the euro tail light stuff is dumb......I cant have the amber bulbs lighting up when I hit the brakes/.
Old May 8, 2015 | 09:07 PM
~STOLEN~'s Avatar
~STOLEN~
DRL and reverse lights are back on when I use the fob.....BUT the amber turn signals still light up when brake is applied....maybe a harness issue directly related to the euro lights and they have always been doing this LOL????
funny part is, the FIRST and LAST time I let someone drive the car is when I noticed the brake/signal issue
SMFH
Old May 9, 2015 | 01:57 AM
SilverC54me's Avatar
SilverC54me
For the Euro tail lights with the proper harness, a white wire on the brake pedal under the dash needs to be cut. This separates the turn signal and brake lights.
If the brake and turn lamps are on when the brakes are applied this is your issue. Fix this and all should work properly.
Gary
Old May 9, 2015 | 08:56 AM
dadaroo's Avatar
dadaroo
Old May 9, 2015 | 10:00 AM
duramaxsky's Avatar
duramaxsky
LED bulbs are polarity and must be installed the right way. If they dont work turn them over and they may work.
Old May 9, 2015 | 01:55 PM
~STOLEN~'s Avatar
~STOLEN~
Gary
found and clipped the wire
THANKS A TON fellas, geez if i would have just read the directions
oh well another thread to be buried lmfao
and BTW, approach fuse under hood was the drl problem.....i wasnt looking past the fuse panel in the footwell that was my fault from the beginning
everything works again
love this forum
Old May 9, 2015 | 02:38 PM
73Corvette's Avatar
73Corvette
Thanks for posting your results and fixes... glad to see you got it all worked out...
Old May 9, 2015 | 05:20 PM
~STOLEN~'s Avatar
~STOLEN~
glad to!!!!
thanks again fellas
To weird problems with electrical **HELP**
