Use your Pucks
Old Jun 3, 2015 | 05:15 PM
Lee DeRaud's Avatar
Lee DeRaud
Originally Posted by Sox-Fan
The holes they snap into are tie down holes. If you're flat-bedded they might use the holes to tie the car down to the bed.
Ok. The last time I was towed, I still had the Porsche: he just wrapped the webbing around/through the wheel spokes and tightened it up...sucker was not going to move.
The hooks on the free ends of the straps hooked into holes in the flatbed, but they looked way too big to fit the holes the pucks go into.
Old Jun 3, 2015 | 05:18 PM
Sox-Fan's Avatar
Sox-Fan
They have little attachments that go into the hole and turn 90 degrees and are then secure. Then the chain or strap goes onto that. Some operators prefer that, it keeps the body from bouncing. Some do the tire thing. I wouldn't know enough to know if there is really a right or wrong.
Old Jun 3, 2015 | 05:25 PM
Lee DeRaud's Avatar
Lee DeRaud
Got it. I could see torqueing down the body/chassis for a long-distance operation, but this was only about 15 miles, and as stiff as that car's suspension was, "bounce" was not really an issue. Come to think of it, that car was even lower (at least between the wheels) than the C5: I'm not sure the widgets you describe would have even fit.
Old Jun 3, 2015 | 05:36 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
I have these
http://www.eliteengineeringusa.com/c...ceted_search=0
Don't worry (too much) about speed bumps rubbing, don't worry about pucks. Just drive the car.
If you want to keep using jacking pucks but want to protect the frame, there is also this model:
http://www.eliteengineeringusa.com/c...nd-mtg-screws/
Old Jun 4, 2015 | 09:31 AM
ArtGle's Avatar
ArtGle
Veteran: Marine Corps
Default Pucks? Who needs Pucks?
As I do 99% of my own work, I got one of these from Harbor Freight Tools.
Works Wonders.
I use a mini-jack to start under the left side of the frame to gain clearance for this under the sub-frame.
The rubber pads catch it exactly right, and the car goes straight up.
Old Jun 4, 2015 | 11:12 AM
JR-01's Avatar
JR-01
Works Wonders.
That's a nice accessory. I use a 2x6, about 2 feet long. I can then put jack stands under both ends and pull jack out giving me room to work.
Old Jun 4, 2015 | 01:20 PM
SaxyVette's Avatar
SaxyVette
I don't do my own work so I'm reliant on others to jack my car. Just glad I got something to protect my rockers.
I don't mind the removeable pucks. Putting them in gives me a chance to talk to the grease monkey about proper jacking technique while doing it
Art that's a beautful setup you got there.
First pic is for Laughs..I needed to shoot a pic under there.
The second shot is the lift that did the dirty deed..
Old Jun 4, 2015 | 01:32 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
man that's a bummer
Is the shop gonna make it right for you?
Old Jun 4, 2015 | 04:34 PM
SaxyVette's Avatar
SaxyVette
I'll find out tonight, Lee is fabricating a small power steering line for me. It's going back on the rack w/pucks this time. I'll have a chance to talk to him anyway. I think probably the crunch was just a simple error on his part,my car had been on his rack before no pucks and no problem.
Old Jun 4, 2015 | 04:46 PM
SaxyVette's Avatar
SaxyVette
Once I cherry out my rockers again this looks like the way to go..
Old Jun 5, 2015 | 02:02 PM
Daddie O's Avatar
Daddie O
I use the leave in pucks too. Also make sure to crack open the doors and hood before jacking up.
Old Jun 5, 2015 | 04:03 PM
Sox-Fan's Avatar
Sox-Fan
Why? This isn't a C3. This car isn't going to sag in the middle when you jack it up.
Old Jun 5, 2015 | 04:20 PM
  #33
Fcar 98's Avatar
Fcar 98
Originally Posted by SaxyVette
I got the actual hockey puck type with the eye screwed in. Only $20 shipped, they're not fancy but they will work if they position the arms of the lift correctly.
Have the same kind of pucks. Don't leave home without them. I Leave them in the car and explain to who ever i have to how to use them!!!
Old Jun 6, 2015 | 02:11 AM
  #34
SG Lou's Avatar
SG Lou
Not necessary on a C5
