Does anyone else wait when starting your car?
Old Jun 23, 2015 | 03:30 PM
  #81
JR-01's Avatar
JR-01
Originally Posted by Lee DeRaud
I know for a fact that it's harmless to wait, and never said/implied otherwise. Necessary or even desirable? Meh, not so much.
Waiting for the fuel system to pressurize is the only real rationale I've seen, but I doubt that takes anywhere near as long as the gauge sweep.
How do you know that as a fact?
Old Jun 23, 2015 | 03:36 PM
  #82
Lee DeRaud's Avatar
Lee DeRaud
You're right, I don't know for a fact that it's harmless to wait for the gauge sweep to finish. For all I know it's the cause of all the C5 problems people have reported here. Happy now?
That aside, the number of diagnostic procedures in the FSM that require key-on-engine-off makes "harmless" a rather reasonable assumption.
Old Jun 23, 2015 | 03:42 PM
  #83
Black 03 Z06's Avatar
Black 03 Z06
Never gave this much thought. In fact I cannot recall exactly what the gauges do once the key is on. I guess I am not terribly observant of these things.
I do however, if the car has not been run in a while, put the accelerator to the floor and crank the engine to get some oil to the top end. As long as it is to the floor the car will not start. No I have no idea why but I am sure some will tell me.
I will keep and eye on the instruments next time.
Old Jun 23, 2015 | 03:46 PM
  #84
JR-01's Avatar
JR-01
The truth is, you don't know if any of it is fact. It is just your opinion, like everyone else.
Old Jun 23, 2015 | 03:47 PM
  #85
Lee DeRaud's Avatar
Lee DeRaud
Huh. Never tried that, so I didn't realize it wouldn't start with the throttle down.
Given that it's a "fly-by-wire" throttle, I have no idea why it would matter.
Old Jun 23, 2015 | 03:52 PM
  #86
JR-01's Avatar
JR-01
It should. In the manual:
2. If it doesn't start within 10 seconds, push accelerator all the way to the floor, while you hold ignition key in START. When the engine starts, let go of the key and let up on the accelerator pedal. Wait about 15 seconds between each try.
Old Jun 23, 2015 | 03:55 PM
  #87
Lee DeRaud's Avatar
Lee DeRaud
The truth is, you don't if any of it is fact. It is just your opinion, like everyone else.
If any of what is fact? The fact that the car will start whether you wait for the sweep or not? Or the fact that the engine won't blow up if you leave the key on too long before you start it? Pick a story and stick to it.
It sure sounds you're busting my chops because I agreed with you: I thought ET was the only one who did that.
Old Jun 23, 2015 | 04:03 PM
  #88
JR-01's Avatar
JR-01
No. If it's beneficial to wait for the sweep to finish or not. Beneficial to the the hundreds of electronic sensors, relays, switches and the computers of the car.
Old Jun 23, 2015 | 04:19 PM
  #89
Lee DeRaud's Avatar
Lee DeRaud
I expressed doubt that it was beneficial...never said that I knew that for a fact. I also never said it wasn't beneficial either.
What I did say was that it is harmless to wait, which seemed to twist your panties in a knot for no apparent reason. Proven fact? No, assuming you're willing to ignore the complete absence of evidence to the contrary. I hope for your sake that it is a fact, since you seem to believe it's not only harmless but beneficial.
Old Jun 23, 2015 | 07:08 PM
  #90
Black 03 Z06
I know in the manual that it says to put the pedal to the floor if the car will not start but I can tell you for certain it will not. The motor cranks, I get oil pressure and then I take my foot off the pedal and it starts immediately.
I believe it is the same thing on C6. I would not say anything about this if I thought someone would damage their motor. Mine simply does not start.
Old Jul 5, 2015 | 02:24 AM
  #91
Radvet's Avatar
Radvet
5th Gear
I always wait and get belted in
Old Jul 6, 2015 | 11:07 AM
  #92
lonerider2002's Avatar
lonerider2002
Originally Posted by lonerider2002
A while back I had the dreaded "service ABS/Traction control" rear it's ugly head and it reset itself after turning it off & back on again-it did it again a few days later. That was over a month ago and since then when I get in to start it I turn the ignition on and wait about 15 seconds for all the bells, whistles, pumps etc to settle down and then I fire her up- and the car has behaved perfectly with no codes remotely related to the EBCM since. Does anyone else take the time to do this and have you had the same result? Not sure if it really has a bearing on anything but so far so good. Mine's a 2002 coupe w/90000 miles.
Back when I posted this I certainly didn't mean for any feathers to get ruffled but I wanted to report that for the last 20 times or so that I waited the 8 seconds ( I mentally count them off ) to start the car there still has been no warnings or codes whatsoever.
So, I figure - if it works, keep on doin' it.
If & when the codes ever return by starting in this manner, you guys will be the next to know.
Old Jul 6, 2015 | 07:27 PM
  #93
lambert55's Avatar
lambert55
I had a similar problem. It ended up being my alternator. It was spiking up to 18 volts. Everytime it did this my gauges blinked off and my dash reset and was blinking waiting for input on all the settings. Replacing the alternator fixed everything.
Old Jul 7, 2015 | 11:43 AM
  #94
xwing's Avatar
xwing
I've had that message before, usually on long trips or storage in hot areas where the components overheated. After things cooled down, no problems. I never wait when starting.
