Need some help/advice!
Old Jun 20, 2015 | 01:39 PM
One78's Avatar
One78
Default Need some help/advice!
Uncovered the car this morning to drive and discovered my drivers side mirror extremely loose. Can twist it around and pull it up easily. Any easy fixes floating around out there? Hate to have to buy a new mirror.
Old Jun 21, 2015 | 08:53 AM
dadaroo's Avatar
dadaroo
See if this link helps at all. If you end up getting a new mirror assembly remember this:
If you are replacing the motor or entire assembly there are 2 types. One with Memory and one without. The one with Memory has 2 connectors, not one. The one with memory has an additional 4 pin connector.
https://www.corvetteforum.com/how-to...mirrors-368457
Here is how to remove the door panel.
http://www.vetteessentials.com/instr...or_handle.html
There may be other info out there if you search, I just provided the first hit I got.
I just looked for: C5 Corvette Floppy mirror
Mr. Sam
