wheel hop
Old Aug 30, 2015 | 10:34 PM
who928's Avatar
who928
Default wheel hop
Had work done on the C5 got up to 550 HP to the rear wheel ., Getting wheel hop in 1st 2nd and 3rd. Have to get out of it to stop WH . Kind of getting upset ,can't get on it . Any suggestions ? thanks Joe
Old Aug 30, 2015 | 10:45 PM
73Corvette's Avatar
73Corvette
https://www.corvetteforum.com/forums...vette-hop.html
Old Aug 30, 2015 | 11:14 PM
StingrayRebel's Avatar
StingrayRebel
what kind of tires do you have?... with that much power you really should be using a good drag radial and that would probably eliminate most if not all of the hop... aside from tires, stiffer motor and diff mounts will help with drivetrain shake
Old Aug 30, 2015 | 11:22 PM
who928's Avatar
who928
what kind of tires do you haveand that would probably eliminate most if not all of the hop... aside from tires, stiffer motor and diff mounts will help with drivetrain shake
netto 555
Old Aug 30, 2015 | 11:34 PM
StingrayRebel
yeah if those are just the basic 555 street tires you are going to have to ditch them if you want to have any fun at all with the power you have
Old Aug 30, 2015 | 11:41 PM
73Corvette's Avatar
73Corvette
If your 550 RWHP... your going to have more problems than just wheel hop... clutch, torque tube couplings, tranny, unless you already addressed those...
Old Aug 31, 2015 | 02:37 AM
RueBurgundy's Avatar
RueBurgundy
if his suspension is shot and/or stock stuff that could be a contributor as well couldn't it?
Old Aug 31, 2015 | 11:44 AM
SuperVetteC5's Avatar
SuperVetteC5
Yes it could. Also a Diff Mount and Tranny Brace setup will help.
Old Aug 31, 2015 | 02:10 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
You need one of these - and hardened output shafts
http://www.customcorvetteaccessories...sionbrace.html
Regards
Chip
__________________
..................Click for
To wheel hop
