No column lock
Old Sep 9, 2015 | 07:04 PM
Brit dex's Avatar
Brit dex
Originally Posted by 8VETTE7
If your car is an auto and the column locks with NO KEY in the ignition then the GM Recall service has NEVER been done to the car.
Are you located in the US ? If not then the recall may NOT apply in your country. Either way I would NOT let a dealer touch the car relative to the column lock system.
It's does lock with no key... No I'm in the UK..
I think for $49 dollars versus it happening.. Bound to be a nightmare time!
It's gotta be done
Old Sep 9, 2015 | 09:28 PM
bob guzzy's Avatar
bob guzzy
When I bought my z06 last fall it had 134K on it, the column was still working.
I bought an economy CLB only to find out no matter what I did it would not work.
This was the first c5 that I bought that I tried the cheaper route, long story short was I sent it back and bought my usual from Texas speed.
Worked first time without any screwing around.
Old Sep 10, 2015 | 12:23 AM
john8642's Avatar
john8642
I have an 03 Z06, and the column doesn't lock with the key out. Does this mean that the recall fix was done on the car? If so, does the LMC5 prevent the 2mph fuel shutoff?
Old Sep 10, 2015 | 12:45 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Recently installed the LMC5 on the 04. After reading the instructions I viewed the video from their website. Then with laptop and paper in hand I set forth. Finished in ten minutes.
The only problem encountered is occasionally after starting and rolling out the garage I get the pull key wait ten seconds routine. Only happens on the first start. I could engage the brown wire, but for now the inconvenience is negligible.
Old Sep 10, 2015 | 06:01 AM
Brit dex's Avatar
Brit dex
Ordered :-).
Old Sep 10, 2015 | 07:20 AM
runner140*'s Avatar
runner140*
That's where I was about a year ago....do the brown wire mod and be done with it.
Old Sep 10, 2015 | 07:39 AM
theheat's Avatar
theheat
St. Jude Donor '12, '14, '17
Old Sep 10, 2015 | 07:54 AM
MikeG37's Avatar
MikeG37
Got mine yesterday
Old Sep 10, 2015 | 02:37 PM
john8642's Avatar
john8642
Column NOT locking with NO KEY in the ignition on a Manual Trans car means that one of 3 things has been done to the car.
1) GM recall variation 04006C was done to the car. Get the GMVIS for the car and find out if GM did recall service on the column lock system AFTER Feb 2006. If so then likely 04006C was done. That installs a small diameter lock plate in place of the full size lock plate and installs a GM K Harness between the lock motor and the connector that goe back to the BCM. K Harness guaranteed to fail the first time the battery goes low.
2) A Column Lock Bypass (CLB) was installed. To know if a CLB was installed you need to drop the drivers side knee bolster and check for the small rectangular CLB box. Looks something like this:
Amazon.com: C5 Corvette Steering Column Lock Bypass Simulator: Automotive
3) An LMC5 may already be installed. This is easy to check. Google Compliance Parts and go to their web site. Look at the LMC5 on their site. In the passenger foot well behind the toe kick at the end of the foot well look for the presence of an LMC5.
Both a CLB and the LMC5 will avoid the 2mph fuel shutoff. They both function the same way in that they fool the BCM into thinking the column lock system is working correctly. Since they are far more reliable than the GM column lock components, the BCM is very unlikely to get out of sync with the CLB or LMC5 and when the BCM is happy it does NOT enable the 2mph fuel shutoff.
You CAN have a tuner with either EFI Live or HP Tuners set the fuel shutoff speed to a high number like 200 or 255. That has the effect of eliminating the fuel shutoff since you are unlikely to get the car to 200 or 25 MPH.
Thanks for the explanation.
Old Sep 10, 2015 | 04:37 PM
pologreen91's Avatar
pologreen91
Not exactly.
ALL C5's have the logic built into the BCM to issue an unlock command to the lock module that is under the plastic tupperware surrounding the steering column. The lock module retracts the pin (if you listen carefully when you insert the key into the ignition cylinder and just begin to turn it toward the ON position you will hear a soft bzzzzzt. That is the pin being retracted by the lock motor.
Same when you remove the key from the ignition, the BCM will send a lock command to the lock motor and the lock motor extends the lock pin. HOWEVER, the lock plate that would normally intercept the lock pin and lock the column is a small diameter plate that CANNOT intercept the lock pin on automatic trans C5's. Those cars were never eligible for the NHTSA forced column lock recall service. It is the GM recall service that screwed the pooch and causes all the problems that you read about on the Forum. The untouched system whether in a manual or automatic trans is generally fairly reliable. Not so with the recall modded system.
The BCM is the same on ALL the 2001 - 2004 C5's and the logic to operates the lock motor is hard wired into the BCM so you have a column locking system of sorts. It is just that the column in an automatic will never physically lock.
Aren't you glad you asked?
Great info, thanks! I've been wondering about this myself.
Old Sep 10, 2015 | 04:41 PM
Lee DeRaud's Avatar
Lee DeRaud
(scratches head) So a late-model auto can't lock, but the BCM can still send the 2MPH cutoff signal to the PCM, right? Or is there logic in the firmware to prevent that?
(I have a 2004 auto and thought the column lock was a non-issue on that configuration, but this is making me nervous...)
Old Sep 10, 2015 | 05:54 PM
jhopper408's Avatar
jhopper408
I'm not gonna fix it until it breaks.
Old Sep 10, 2015 | 06:03 PM
  #33
jhopper408's Avatar
jhopper408
I'm not gonna fix it until it breaks.And if it breaks I'll have it towed, and then pay to have it fixed.
Old Sep 10, 2015 | 06:29 PM
  #34
Lee DeRaud's Avatar
Lee DeRaud
What you are NOT understanding is that the 2mph fuel shutoff was a part of the GM Recall Service for Manual Trans cars. They reflashed the PCM to set the speed to 2mph.
Ah, got it, thanks.
Old Sep 10, 2015 | 06:33 PM
  #35
jhopper408's Avatar
jhopper408
Originally Posted by Lee DeRaud
Ah, got it, thanks.
Ah got it! Like I said! I'll have it towed, and then repaired. Geeze..
Old Sep 10, 2015 | 06:39 PM
  #36
Martinez310's Avatar
Martinez310
Veteran: Marine Corps
St. Jude Donor '14-'15,'19
yes i highly recommend it .. it a pretty scary situation
Old Sep 10, 2015 | 06:40 PM
  #37
73Corvette's Avatar
73Corvette
I'm preeeetty sure he wasn't even replying to you
To No column lock
Old Sep 10, 2015 | 07:17 PM
  #38
Lee DeRaud's Avatar
Lee DeRaud
Yup. His last couple of posts look like they're coming from a smartphone that's smarter than he is.
Old Oct 13, 2015 | 08:41 PM
  #39
crazychucky8's Avatar
crazychucky8
Hey 8VetteZ - Based on several posts, you appear to be very knowledgeable with the Steering Column Lock issue. I have an '02 Z and the Positive Battery terminal was apparently lose. It was creating low voltage issues that simulated an issue with the Alternator. Pulled the alternator, tested it an passed. This is when I did further investigating and found the lose terminal. Replaced the terminal bolt and recharged the battery. Took a multimeter to the battery after charging the battery. The battery is a 12.5 volts. Started the car and I now have the Steering Column Lock issue. My steering wheel still turns with the key not in the ignition, so, i'm assuming the recall was done prior to me purchasing the car. At this point the vehicle shuts off at 2 MPH.
My question, based on other posts, I'm confused as several other posts said that once the Lock issue occurs you have to take to GM to get it fixed. Your posts however indicate that I can purchase the LMC5 device install it and the issue will go away. Is this true?
Thanks for your help!
Old Oct 13, 2015 | 09:35 PM
  #40
crazychucky8
The statement in BLUE above is NOT correct. GM never has had a permanent fix for the Column Lock Symptoms. If they did you would not be posting these questions.
Order and install an LMC5. Save the install instructions because there is a small chance you may need to do the "brown wire mod" explained on page 2 of the install instructions.
With the LMC5 you do not need to know what has been done in previous attempts to correct the Column Lock Symptoms. Properly installed the LMC5 abandons all column lock wiring and/or components down stream of the BCM. LMC5 installs right at the BCM.
Google "Compliance Parts" to read about the LMC5 and order it.
Also as an FYI, if the voltage at the battery posts is only at 12.5 volts and not higher like 12.7 or higher, the battery is marginal at best (assuming you did in fact attempt to fully charge it). Expect to have to replace it soon. Car starts with 12.2 volts or less but the electronics in the C5, ESPECIALLY the column lock electronics, are NOT happy with 12.5 or less..
Thanks for the quick response! I tried to make that argument about the Voltage at Autozone and no one seemed to agree with me. I let the battery charge for 48 hours at this point. I've placed an order for the LMC5. The battery will be next! Thanks for your help!
