[Z06] Oil Burning Smell - On going problem
Old Nov 1, 2015 | 12:05 PM
Tebo38's Avatar
Tebo38
Default Oil Burning Smell - On going problem
Well for the passed few week I've had the problem of a burning oil smell coming from under the hood when my zo6 gets up to temperature. I've changed both valve cover gaskets to make sure that wasn't the problem and its still smoking under the hood and gets me frustrated every time it happens. Just wanted to see where you guys think i should be going/looking next with this because I'm sure I'm not the only one this has happened to
Old Nov 2, 2015 | 09:57 AM
Stroker87's Avatar
Stroker87
what area are you seeing the smoke from?
it could be from any place front or rear engine cover, valley cover, oil pan, oil pressure sending unit really hard to say with out know what area you see the in?
Old Nov 2, 2015 | 12:17 PM
Breze84's Avatar
Breze84
Do you have a valve cover breather? If not make sure that the actual oil cap and neck are sealed good. The neck twists inside of the valve cover and is sealed with a O-ring. Also feel around the back of your Cylinder heads and valve covers and see if you feel any saturation. I would also get the car up in the air and make sure your plug is snug and your oil filter is snug....
Old Nov 2, 2015 | 05:08 PM
Zjoe6's Avatar
Zjoe6
Old Nov 2, 2015 | 11:56 PM
Tebo38's Avatar
Tebo38
to me it looks like it is coming from the drivers side by the headers. As soon as it smokes i try and find a place to pull over to look at. And it seems to come from there. Like one of you said, I'm going to get it up in the air some time when it gets a little warmer than 50 this week to really try and see if i can find the problem. I'm going to look into the oil pan gasket as well.
Old Nov 8, 2015 | 08:37 AM
Atok's Avatar
Atok
Check out this thread.
https://www.corvetteforum.com/forums...lp-please.html
What I ended up doing was clean it up real well with brake clean and degreaser, then forced some ultra-black silicone in the tiny hole that was spitting oil. It has been about 80% effective but I think it still seeps a tiny bit. At least it's not spitting it onto the exhaust now. Really poor machining in this area, looks like rough cast.
Old Nov 26, 2015 | 07:36 PM
Tebo38's Avatar
Tebo38
I'm thinking i have the same problem. Thanks!
To Oil Burning Smell - On going problem
