Locking unlocking doors
Old Dec 6, 2015 | 05:49 PM
yanmar's Avatar
yanmar
Default Locking unlocking doors
after having my battery out , now the key fob will not lock or unlock doors. what is the procedure to reprogram . thanks ..........
Old Dec 6, 2015 | 06:33 PM
JR-01's Avatar
JR-01
1. Turn the ignition key to ON.
2. Clear any warning messages on the Driver Information Center (DIC) by pressing the RESET button.
3. Press the OPTIONS button on the DIC several times until the blank page is displayed, then press and hold the RESET button for two seconds.
4. When the message FOB TRAINING is displayed, push the RESET button once. The message HOLD LK + UNLK 1ST FOB in the DIC will be displayed.
5. Press and hold the LOCK and UNLOCK buttons on the transmitter simultaneously for 15 seconds.
6. When a transmitter is learned (matched), the DIC will display FOB LEARNED and then prompt you to learn the next transmitter.
7. Repeat Steps 5 and 6 for each additional transmitter.
8. Remove the key from the ignition.
The programming mode will shut off if:
You don’t program any transmitters for two minutes.
Old Dec 6, 2015 | 06:54 PM
yanmar's Avatar
yanmar
Thanks jr-01 it worked
Old Dec 7, 2015 | 06:01 AM
dadaroo's Avatar
dadaroo
You need to get and read the owners manual
Mr. Sam
Old Dec 7, 2015 | 07:54 AM
calvins's Avatar
calvins
Oldtimer
Good job jr! That's what the forum's for - helping and exchanging info.
Old Dec 7, 2015 | 08:12 AM
65GGvert's Avatar
65GGvert
If it happens again, hold down the lock and unlock buttons for several seconds till the horn honks. What you did was relearn the fobs, which is fine. But when you disconnect the battery, and sometimes when you remove the battery from the fob the rolling code gets out of sync. If you stand near the car and hold down the two buttons on the fob, the code is RESYNC'D. This will only work if the fob has previously been learned by the car, so just any fob wont sync to just any car.
Summary: If your fob stops working all at once for any reason, first try just holding down the lock and unlock buttons for a few seconds. If it doesn't work, you can always use the relearn procedure to see if that will get them back.
Old Dec 7, 2015 | 10:37 AM
JR-01's Avatar
JR-01
Thanks. I too, will have to remember that.
To Locking unlocking doors
