Auto to manual conversion HELP!
Old Dec 21, 2015 | 07:55 PM
Calderon209's Avatar
Calderon209
Default Auto to manual conversion HELP!
I have a 1999 auto c5 and I want to convert it to a manule. I have a friend parting out at 2004 c5 and gonna be getting the swap with rear end from him for a pretty good price. My question is what all do I need. Flywheel back. Clutch and brake pedal, clutch reservoir, tranny, rear diff, and tranny harness. WHAT ELSE WOULD I NEED! Help
Old Dec 21, 2015 | 10:36 PM
momo20's Avatar
momo20
did a quick search as i was curious too this guy did one and has a lot of really good info on there
http://www.digitalcorvettes.com/foru...d.php?t=152821
Old Dec 22, 2015 | 02:19 AM
Evilash's Avatar
Evilash
Shifter, tune, clutch res bracket, remote bleeder, under dash wiring.
Went this route with fairly low cost used z06 trans/tt, pedals, res, ect. Already had z06 rear end in it
Still cost $5,000.
You'll spend another grand just on support parts, another on a dyno tune. Not to mention labor.
Unless the rest of your car is all modded out I wouldn't do it. My whole car was low mileage and the full exhaust and new ls2 engine and suspension were done so I thought it was worth it since the auto was toast and the rear cover needed replaced.
Not really worth it especially if you are mostly stock.
Old Dec 22, 2015 | 03:19 AM
Calderon209
What do you mean by support parts?
Old Dec 22, 2015 | 09:15 AM
jackthelad's Avatar
jackthelad
Unless you really want to do the project, it would be cheaper - and a whole lot easier - to sell your auto C5 and buy a 6 speed. Also, a good opportunity to get a later car without the parts unavailability of the early year cars.
Old Dec 22, 2015 | 10:01 AM
Calderon209
Well I'm getting whatever I need off the car for $1,300 so that's why I'm saying what else would I need specifically
Old Dec 22, 2015 | 02:53 PM
Evilash's Avatar
Evilash
While it is apart you'll want to do things like the couplers, maybe the shifter, remote bleeder, two long bolt starter,mounts, rear main, things that would save you from breaking it down again.
Old Dec 22, 2015 | 10:55 PM
Here's a write-up that was here on the forum back in 2011.
Old Dec 23, 2015 | 04:35 PM
jackthelad's Avatar
jackthelad
You might want to make contact with this guy:
http://www.corvetteforum.com/forums/...it-s-good.html
To Auto to manual conversion HELP!
