Harmonic Balancer-Preventative Maintenance
Old Mar 4, 2016 | 08:05 AM
  #41
jimmyLSX's Avatar
jimmyLSX
Originally Posted by Evil-Twin
I can tell you it's a labor intensive job. Not one to be taken lightly. 800 dollars is a fair price.
You have to take out the radiator and condenser as well, also its very important to replace the front crank seal. No one of any mechanical aptitude that gets 50 to 90 dollars an hour ( shop time ) could do this job for 100 dollars. OEM balancer is 80 dollars, a good After market balancer is 200 dollars. this is a 1000 dollar job at any reputable shop.
Some asked about how common this problem is.. With the longevity of these cars, its not if... it when.
There are two issues
1) inter fit of the crank OD to ID of the Balancer failure over time. ( Bolt backing out )
2) loss of the elastomer bonding agent between the two segments. ( Causing the outer race of the balancer to separate from the rest of the balancer and the crank shaft.
Loss of the balancer could potentially destroy your motor when the crank runs severely out of balance due to a balancer failure. You will feel the vibration, but quick action and a tow could save you..
With loss of the elastomer, same thing happens but sometimes you will see and hear chucks of rubber separating from the balancer. see evidence on the garage floor ( if you are lucky.
If the balancer moves front an back and destroys the front seal integrity, say good by to your motor.
Not trying to scare anyone, but this is a problem that needs some attention. a C5 runs hot under the hood only adding to the drying out process of the elastomer, which holds both elements of the balancer together..
Good luck
Bill aka ET
Why does the condenser and radiator need to come out? I plan on installing a ATI balancer in two weeks from now, I wont have to worry about the hubs od and id because im pinning my crank? Right?
Old Mar 4, 2016 | 08:53 AM
  #42
tbrowne's Avatar
tbrowne
The radiator and fans need to be removed to give clearance to access the balancer. The condenser does not need to come out - it can be pulled up and out of the way if needed. The car was designed to allow the condenser to be pulled up by a foot or more without disconnecting any fittings to the condenser. The engineers got this one right! It's hard to visualize but you'll see what I mean if you do the job yourself. There isn't much room to work even after the necessary items are removed, so take your time, plan it well and do it right. It's not something most of us would want to do again for at least a few years.
Old Mar 4, 2016 | 09:59 AM
  #43
Dark Syde's Avatar
Dark Syde
Cruise-In VII Veteran
Originally Posted by Christian327
As a matter of fact, I just checked and I do have an oil leak on the front of the engine. Or at least oil buildup that shouldn't be there...Is that a dead giveaway for this problem?
I also had an oil build up around the crankshaft area. I expect that is due to the oil seal leaking, which is likely caused by the constant "wobble" of the HB. The dead giveaway was the wobble that is much easier seen than the oil buildup. Replaced both HB & seal last week for $450 and am back on the road and HAPPY!
Old Mar 4, 2016 | 10:19 AM
  #44
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
when I said out, I meant out of the way.. radiator has to be removed, condenser can be just moved out of the way but has to be moved. there is no room to work..
Old Mar 4, 2016 | 06:34 PM
  #45
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
When we perform a replacement on a balancer, we always do the front seal and the front cover gasket. It also requires a balancer bolt as mentioned as it is a torque to yield bolt (the threads stretch when torquing it down to approx 250 lb ft.). The job should also include water pump gaskets. It is an ideal time to replace both the drive belt and the a/c belt as they are removed during the process.
We charge 6 hours of labor on a C5 -@$105 per hour.
