When installing headers, what else should you do?
Old Jan 18, 2016 | 12:13 PM
imgn tht's Avatar
imgn tht
St. Jude Donor '13, '15
Default When installing headers, what else should you do?
I have a 2004 coupe, automatic with 24,000 miles. Current mods include: blackwing intake w/smooth coupler, ghl bullet catback. The car is a 3-season daily driver for a 10 mile roundtrip commute. Not many long distance runs beyond 40-60 mins max.
In the Spring I'm planning to purchase a set of XS Power headers with catted x-pipe. Thinking ahead to anything else I should budget for when installing the headers.
My thoughts were:
1. New spark plugs and wires
2. Heat wrap for starter
3. Tune
4. Ceramic coat for the headers.
5. Cool sox for plug wires...think that is what they are called.
So questions are...anything on my list I don't need to do, and what else am I missing that is either good to do for preventative maintainance, or best to do for installation convenience?
Old Jan 18, 2016 | 12:21 PM
Witmer's Avatar
Witmer
I'd consider adding a thicker chassis tunnel plate with heat shielding while the entire exhaust is out.
Old Jan 18, 2016 | 12:30 PM
That would make a difference in the car and be easy to do with the exhaust already out.
Old Jan 18, 2016 | 12:32 PM
imgn tht's Avatar
imgn tht
That's to keep the heat from the exhaust from entering the interior right?
Old Jan 18, 2016 | 12:44 PM
jpm995's Avatar
jpm995
Good time to add a supercharger.
Old Jan 18, 2016 | 12:49 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Pounder's Avatar
Pounder
1/4 mile/AutoX
Originally Posted by jpm995
good time to add a supercharger.
yup !!!!!!
Old Jan 18, 2016 | 01:15 PM
imgn tht's Avatar
imgn tht
Unfortunately not in the budget. But it would be nice.
Old Jan 18, 2016 | 10:17 PM
imgn tht's Avatar
imgn tht
Just thought about one more....added to the original list. Cool sox for the plug wires.
Old Jan 18, 2016 | 11:17 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
check your motor mounts,see if they are leaking, you have low miles, sometimes that doesn't mean anything ??????
Old Jan 19, 2016 | 10:18 AM
roscoe118's Avatar
roscoe118
Plugs and wires are a good idea. Cool socks and starter wrap are not necessary, especially if you have the headers coated, but can't hurt anything to do if you don't mind spending a little extra cash.
You'll be very happy with this mod and a tune...
These exact mods added right at 45 RWHP to my '02 MN6.
Old Jan 19, 2016 | 12:15 PM
Sam Handwich's Avatar
Sam Handwich
following
Old Jan 19, 2016 | 01:43 PM
imgn tht's Avatar
imgn tht
Thanks for the info. I haven't begun to price out the cool socks and wrap yet, so I'll check that out. Thinking I may pass on the tunnel plate as well, only because it is quite pricey and not sure my driving habits will ever see a noticeable difference in cabin temps.
Old Jan 19, 2016 | 03:03 PM
Witmer's Avatar
Witmer
Correct. A thicker tunnel plate will also increase chassis stiffness. Would be nice if doing the occasional track day.
Old Jan 19, 2016 | 03:59 PM
Mickeyrx70's Avatar
Mickeyrx70
Consider aluminized sleeving for AC lines that run close to the headers. You can also use them to protect O2 wires. Check Design Engineering Velcro Aluminized Sleeving 36" Heat Shroud (DEI 010495) on Amazon.
Old Jan 19, 2016 | 04:54 PM
DetroitPlac's Avatar
DetroitPlac
I bought these for the wires and they're fantastic. Far cheaper than I could find anywhere else, and they stood up fine to repeated track use.
http://www.ebay.com/itm/GM-LS1-LS2-LS4-LS6-LS7-Spark-Plug-Wire-Boots-Black-8Cyl-Made-In-USA-/231391022160?hash=item35dffacc50
And it's very wise to have replacement wires on hand. No way you'll get the old ones off without destroying them, especially if they're original.
Finally, x2 on the motor mount suggestion. My XS Power headers rub, but its likely due to a collapsed motor mount that I just NOW realize is the problem. The best time to change the mounts is when you have the exhaust manifolds/headers off. Check closely for leaks and plan on swapping the mounts if need be.
Old Jan 19, 2016 | 05:37 PM
chassed's Avatar
chassed
Beer
To When installing headers, what else should you do?
Old Jan 19, 2016 | 05:43 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Originally Posted by chassed
Beer
LOTS !!!!!
Old Jan 19, 2016 | 09:23 PM
91LSMAN's Avatar
91LSMAN
I was thinking about this as well.
But I'm always thinking about different things to do to my vette.
Old Jan 19, 2016 | 09:25 PM
The03Z's Avatar
The03Z
You might as well replace all the exhaust hardware/fasteners while you're at it.
