Need your input plez
Old Jan 20, 2016 | 06:35 PM
lectroglide's Avatar
lectroglide
Default Need your input plez
am looking ata 2002 coupe silver in color gray/black interior auto with 78K on the clock. prolly 85% left on tires. Seems to shift fine with no strange noises etc. has lotsa power when floored!! body /interior/ engine compartment looks to be straight along with "no curb rash " on stock wheels. One thing I did notice is their was water/moisture coming from around the window areas, so not sure what the cause is.>>>>>>>>>>>the car is on a lot asking price is $13K , what would you pay for this car??
Old Jan 20, 2016 | 07:33 PM
Pappy11's Avatar
Pappy11
Seems to be a good price...every area is different on prices...they are all over the place. I paid way more for my 02 very with 47 k on it....be sure to check the section on buying a c5
Old Jan 20, 2016 | 07:47 PM
73Corvette's Avatar
73Corvette
https://www.corvetteforum.com/forums...ion-files.html
Old Jan 20, 2016 | 07:56 PM
JR-01's Avatar
JR-01
Good price, if no major problems.
Old Jan 20, 2016 | 08:05 PM
Not a bad price, but I would see if the source of the water leak can be found prior to purchase. It could just be some adjustments needed or the weatherstripping needs repaired. If you decide to purchase the car, I do have some Word files on C5 water leaks that could help you figure it out.
Old Jan 20, 2016 | 08:13 PM
v98roadie's Avatar
v98roadie
Trucker
Water and moisture around the windows? If you mean condensation build up on the windows when they're up and the doors are closed that might indicate moisture in carpet and upholstery, that could be trouble. I would spend a few bucks on a CarFax just to see what it shows. The price is good if the car just has normal wear and tear. Good luck.
Old Jan 20, 2016 | 09:31 PM
Chopnspray's Avatar
Chopnspray
Check around the rear bumper ,looks like its been painted before by looking at the pic.
Old Jan 20, 2016 | 09:53 PM
Doughan's Avatar
Doughan
Elite Member
Cruise-In III Veteran
The urethane bumpers often don't match perfectly, not a big deal. Check for mildew and dampness on the carpets and check the DIC codes. I'd offer 11k and maybe meet in the middle.
Old Jan 20, 2016 | 09:56 PM
Kevinl's Avatar
Kevinl
Based on what you said and looking at the pictures it appears to be a fair price barring any surprises.
Old Jan 20, 2016 | 10:38 PM
Choreo's Avatar
Choreo
If it is what you are looking for, then price looks good to me. I would not be too concerned about the moisture issue - whatever it is, it is easily fixable.
Old Jan 20, 2016 | 10:51 PM
lectroglide
$11 is here I started thanx for the other replys
Old Jan 20, 2016 | 10:58 PM
Chopnspray's Avatar
Chopnspray
I know that I do high end restorations and custom paint work,the color looks pretty far off to me in the pic compared to the front bumper which has a better match.
Old Jan 20, 2016 | 11:16 PM
El original's Avatar
El original
Have them do a pressure test on the cooling system to assure no leaks in heater core. Excellent looking Corvette (I am a silver freek) Don't think you can shop this one for the condition and price! See if they can spring for a front licence plate filler...cost is over $100- Good luck
Old Jan 21, 2016 | 06:42 AM
3sACROWD's Avatar
3sACROWD
Moisture on the windows and air freshener on the vent would make me inquisitive. It could be that they recently cleaned the carpets though. Time for investigation.
Pull the air freshener and check the carpet for dampness and musty smell. On the passenger side floor, there is a compartment with the BCM in it. Open that compartment and investigate for moisture. Obviously moisture and computers don't mix.
The problem could be a simple fix like the udders under the hood need to be cleaned out. Also pull the codes to see if there are any major ones. The procedure can be found on this site. http://api.viglink.com/api/click?for...c%2Fdtcdic.php
If you really like the car, approach the deal with a level head and find the cause of the moisture. Don't let your emotions overtake common sense. There are other Corvettes out there if this one doesn't pan out. Good luck!
Old Jan 21, 2016 | 07:21 AM
Shakeydeal's Avatar
Shakeydeal
I wouldn't pay anything for it because I don't like the exterior or interior color.
That said, if you like the color combo, then it seems like a fair price.
Shakey
Old Jan 21, 2016 | 12:13 PM
lectroglide
Shakey
to be honest I don't care for the interior colors either, too bright and hard to keep up. one thing Ive learned was hoping to find one red in color then I seen how easy the silver would be to keep up, so ofcourse now the red is out, besides am not too keen buying a "lot vehicle" which most come from auctions, so ya never know
Old Jan 21, 2016 | 12:27 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Originally Posted by riversidedan1
to be honest I don't care for the interior colors either, too bright and hard to keep up. one thing Ive learned was hoping to find one red in color then I seen how easy the silver would be to keep up, so ofcourse now the red is out.
If you don't like anything about the colors in or out...
...keep looking.
To Need your input plez
Old Jan 21, 2016 | 01:01 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Moisture on the INSIDE of the car windows ALWAYS indicates that there is WATER / DAMPNESS,, somewhere inside the car. It evaporates and condenses on the inside of the cooler windows. PLAIN AND SIMPLE!
YOU NEED TO FIND IT and figure out HOW/WHY its getting inside.
Could be something as SIMPLE as someone had wet feet and the carpets got wet OR someone left the window down during a rain storm OR as complex as BODY DAMAGE from an ACCIDENT that cant be or was improperly repaired.
FIRST THINGS FIRST.
Move BOTH seats all the way UP and FORWARD. The carpet on the rear wall of the foot well covers the flap on the floor carpet in both foot wells.. Pull UP the rear wall carpet and find the foot well carpet flap. Put your hand under the carpet and under the carpet padding (JUTE) and see if there is any water OR moisture. If either side is WET,, you have a LEAK.
There are numerous areas where the water can enter the cabin. Some are easy to FIX and some are a royal Pain In the **** to fix.
Sometimes, the only way to figure out where the water is leaking is to REMOVE the seat and the foot well carpet and HOSE down the car.
There can even be water/leaks in the REAR compartment that collects in the storage wells. Best check that area also.
Some people have stated to ME,,,,,, " How can I have water in my vette. I NEVER DRIVE IT IN THE RAIN!"
1, DO YOU WASH YOUR CAR????
2. Do you run your AC??? (If you run the AC, condensate will build up in the HVAC Air Box.) There is a dedicated drain to allow it to drain out on the ground. IF,, that drian plugs up,,, IT WILL LEAK INTO THE PASSENGERS FOOT WELL and Onto the Body Control Module! BAD DAY FOR THE BCM!
I could go ON AND ON about leakage in the C5. Been there done that. If you own a ZO6, there another entire CHAPTER on leaks for that body style!!!
NOTE and WARNING. A unmolested dry, well cared for C5 DOESNT NEED an air freshener! If they feel the need to COVER UP the interior smell,,,,,,,,,,,,,,,,, SOMETHING IS NOT RIGHT!! Usually its from leaving wet carpets inside the car to dry out on their own and the MILDUE starts to form!
Old Jan 21, 2016 | 03:00 PM
CQRT's Avatar
CQRT
Heater core maybe? There would be a definite smell and dampness in passenger foot well. But it could also be from carpet cleaning preparing the car for sale? And that's a terrific price from my perspective if everything else checks out.
Good luck.
Old Jan 21, 2016 | 03:48 PM
eps930's Avatar
eps930
