Headlights
Old Jan 27, 2016 | 12:38 PM
808EB03Z06's Avatar
808EB03Z06
Default Headlights
I am about to make a cross country trip and have no trust in the stock headlights. does radioflyer still make the ACA projectors, or is there another option that increases light output?
Old Jan 27, 2016 | 03:58 PM
MAC5's Avatar
MAC5
George just posted availablity of ACA kits last week, see the link
https://www.corvetteforum.com/forums...adioflyer.html
Old Jan 27, 2016 | 05:54 PM
Sam Handwich's Avatar
Sam Handwich
you are making a smart move if you get those ACA bi-xenon lights. You will feel very safe driving your vette at night
Old Jan 27, 2016 | 08:22 PM
Clancy209's Avatar
Clancy209
U can get a 2-4 harness (hope I got that right) when u use the bright lights all four lights come on. I believe radio flyer sells the harness. May not be the best solution but it helps
Old Jan 28, 2016 | 06:24 AM
LoneStarFRC's Avatar
LoneStarFRC
Hi-4 harness.
Old Jan 28, 2016 | 07:59 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I just upgraded my original ACA HID kit to Radioflyer's Bi-Xenon kit. I thought my originals were very good, but the Bi-Xenon are even better.
My original set will be posted in the For Sale section soon.
Old Jan 28, 2016 | 08:02 AM
Velocity_Vette's Avatar
Velocity_Vette
http://blog.brianmoses.net/2013/11/addressing-the-terrible-headlights-of-the-c5-corvette.html
This is a good blog post about converting over to an HIR bulb. This is becoming a very common application now that HIRs are somewhat coming down in price.
9011 HIRs and 9012 HIRs are very similar in construction and application other than minor variances in the set tabs on the bulb's base, which can be trimmed to fit the C5s housings that typically accept a 9005 and 9006 bulb. The HIRs pull no additional power than the stock 9005s and 9006s while providing brighter light output. While your resultant light output will not be on par with a projector setup, it will be an improvement.
Old Jan 28, 2016 | 12:27 PM
oh1vette's Avatar
oh1vette
and probably $600 less expensive
Old Jan 28, 2016 | 01:16 PM
El original's Avatar
El original
I like the idea of the Hi-4 harness and some high output stock fit halogen bulbs have to do the trick and save you lots of $$$$ for you trip ahead.
Old Jan 28, 2016 | 02:42 PM
808EB03Z06's Avatar
808EB03Z06
Thanks for all the input everybody. I may look into the 9011/9012 idea to at least see the improvement.
Old Jan 28, 2016 | 02:45 PM
Sam Handwich
great.
please report back on what you do and how it works
Old Jan 28, 2016 | 03:18 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I second that notion....
Toque
Old Jan 28, 2016 | 03:20 PM
Sam Handwich
Toque
me too. Or is it mee three?
Why pay twice, when you can do it right the first time?
Old Jan 28, 2016 | 04:04 PM
pups's Avatar
pups
i did this on my 90 GMC, the bulbs are only about $25 a pc, so nothing crazy
Old Jan 28, 2016 | 04:23 PM
808EB03Z06's Avatar
808EB03Z06
Originally Posted by Sam Handwich
great.
I most certainly will. Hell I may just try it tonight.
I will go with the ACAs if doing the 9012/9011 switch doesn't satisfy me.
Old Jan 28, 2016 | 04:27 PM
808EB03Z06's Avatar
808EB03Z06
I would take a gander that the light output looks better in person than it does in the picture?
Old Jan 28, 2016 | 04:46 PM
pups's Avatar
pups
yea, can hardly tell in the pics, but it is noticeably brighter in person. Not HID bright, but an improvement over stock.
To Headlights
Old Jan 29, 2016 | 12:33 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
our Bi-xenon ACA (before/after)
http://shop.radioflyerinnovations.co...lights-015.htm
Factory Low beam
Bi-xenon ACA low beam
Which would you rather have at night?
Old Feb 4, 2016 | 03:30 PM
ND2GOFASTER's Avatar
ND2GOFASTER
Any complaints on other drivers flashing because they're blinded by the Bi-Xenon lights. How much adjusting needs to be done?
Old Feb 4, 2016 | 03:44 PM
TheRadioFlyer
Supporting Vendor
If aimed correctly the only time oncoming traffic will have issues is on hills, but that happens with all but auto-leveling headlights.
Adjusting mostly needs to be done on the driver's side to bring it UP and LEFT. Because of the sharp cutoff on the low beam, you can aim the headlight much higher than with a traditional reflector headlight without risking glare to oncoming traffic.
