Cutout switch install help
Running the wire for my new cutouts and need to know where to tap the wireing in to get power. Or do you run the power wire directly to the battery? Thanks
So I'm using the console cig lighter hole to mount my button and tapped into the cig lighter wireing. It opens the cutouts. My question is will this cause any type of battery drain bc this allows you to operate the cutouts with no key in at all.
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
I currently have the switch for my QTP cut outs in the center console where the power outlet was. I have been looking at the LG Man **** with the switch built in to the shift ****. I have a C6 shifter in the car already and I am looking to see if I can adapt the wiring on the LG **** to run the QTP cutouts.
