Z06 Gauge question ?
Old Apr 6, 2016 | 02:07 PM
Skrilla's Avatar
Skrilla
Default Z06 Gauge question ?
I prefer the font of the Z06 gauges but don't want my cluster to say Z06 if it's not . Does anybody make an aftermarket set without Z06 on them? Worst case is the Z06 ones plug and play ?
Old Apr 6, 2016 | 02:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES,,,,,,,,,, All C5 IPCs are plug and play. If you have a HUD, the one you replace it with needs to be HUD capable. If not, it really doesn't matter if it has a HUD connector receptacle or not.
I do not know the cross over date but,, some newer IPCs have a different AIR BAG indicator location and the bulb needs to be changed to that spot.
NOTE! Your cars mileage is computed and stored on an IC Chip on the IPC main mother board. If you swap in another IPC, the mileage will most likely NOT be the same as your car.
Here are some IPC post that will get you familiar with what on the inside:
- C5 Gage Cluster disassembly - http://forums.corvetteforum.com/c5-t...post1570380674
- C5 Gage Cluster Post - http://forums.corvetteforum.com/c5-t...post1570380878
