Regular Gas ok?
Old Apr 13, 2016 | 06:07 PM
  #41
Pounder's Avatar
Pounder
1/4 mile/AutoX
^^^^ Bill I have a friend who bought a new C 7 in 2014, the first time I got to ride in it he stopped to get gas. I went in to get us a pop, I came out and said your putting regular in there ??? I said it takes Premium, he just said the owners manual recommends Premium to which I said for a couple bucks. It won't hurt anything, I said feel bad for the next owner !!!!
Old Apr 13, 2016 | 06:13 PM
  #42
Crussader's Avatar
Crussader
Originally Posted by danny99
...the driver side door won't lock with the key remote fob.
Try holding down the Lock and Unlock buttons at the same time. Keep holding them down until the horn honks (about 7 to 10 seconds). That will reset the fob if it has gotten out of sync.
Old Apr 13, 2016 | 06:24 PM
  #43
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I've paid 4 dollars a gallon for premium in the past, and could care less.... I have no control over the prices, but I know what the car requires. I'll play it safe with the security of having enough octane when the car needs it. I drive the car mostly in the summer, where it is absolutely necessary. I'm not going to try to save a few buck, when I know and can feel confident putting the best fuel I can get. Lots of people " Think " 15000 mile oil will last for 15,000 miles, are the same ones who think regular fuel is all that is required, when in fact regular fuel was never recommended in the first place. Just from a Logic point of view, with compression ratios north of 10.3:1... being one of the most powerful motors developed. What do these regular fuel advocates, think all the premium fuel at each gas station is for? Same for the oil... its very specific for a Y body ( bottom breather ) specific because ita normal run temp is much higher than a conventional engine. The guys who run regular fuel, extend their oil way past its oil life, and use just any oil, are the ones who pass on these disasters to un knowing victims of their abuse.
Old Apr 13, 2016 | 06:27 PM
  #44
Evil-Twin's Avatar
Evil-Twin
IM going to bale out of this thread..... my calm down meter is beeping.
Hope the OP good luck with his car, and hope he can find the right people on this forum to help him in time of need... as I always say to a Newbie to the forum....." be very careful who you listen too here "
Bill aka ET
Old Apr 13, 2016 | 06:36 PM
  #45
Vanover's Avatar
Vanover
Originally Posted by The Rabbi
My first guess is there is a lot less demand for premium than the old days. Maybe the taxes are higher for the gas hogs.
Gas hog?im happy with 28 mpg.what do you get?
Old Apr 13, 2016 | 06:38 PM
  #46
captaineddie's Avatar
captaineddie
I say, take your car to a reputable mechanic/repair shop, get all the fluids, belts, and hoses changed, put new tires on if the build date is too long ago, and then take the car out and enjoy it. All these worries may turn out to be a moot point.
Old Apr 13, 2016 | 06:43 PM
  #47
Vanover's Avatar
Vanover
Slite change,what happens with to much octane?
Old Apr 13, 2016 | 06:46 PM
  #48
Pounder's Avatar
Pounder
1/4 mile/AutoX
you go faster
Old Apr 13, 2016 | 06:48 PM
  #49
Forcedvert's Avatar
Forcedvert
I think what gas to use has been covered, so I won't comment on that.
But I will say some remedial math is in need for people to figure out how much more premium gas is as a percentage, and how much more 16 gallons will cost you on a complete fill up.
Old Apr 13, 2016 | 08:16 PM
  #50
Fast Cars & Horses's Avatar
Fast Cars & Horses
I go out of my way to put 93 octane in mine at $3.85 a gallon, but I can tell a difference. The annoying minor occasional ticking has disappeared and maybe it's me, but I can feel more power on take off. I change oil with Royal Purple every 3000 miles NO MATTER WHAT THE OLM SAYS because I am now autocrossing nearly every other weekend at least. I love this car and I want to do what it takes to make it last a long long time and perform at it's best.
Old Apr 13, 2016 | 08:21 PM
  #51
Pounder's Avatar
Pounder
1/4 mile/AutoX
YOU GO GIRL !!!!!!!
Old Apr 13, 2016 | 08:42 PM
  #52
airforcex's Avatar
airforcex
Dear all,
Is regular gas Ok in a 2002 base coupe? The original owner told me they've always used regular gas, car has 20k miles on it.
No harm to continue using regular? or should i switch to mid, or premium?
Upgrade to premium and don't worry about it.
Old Apr 13, 2016 | 11:02 PM
  #53
RC000E's Avatar
RC000E
Originally Posted by CriticalmassGT
I always use premium. But that's my choice. My car will compensate for 87 octane, same as yours. It retards timing if it detects spark knock.
Since you encourage the use of a reduced octane fuel, please be clear and define how your car "detects" spark knock, via the knock sensors. What has to happen, specifically, for the knock sensors to request a timing alteration?
Old Apr 13, 2016 | 11:12 PM
  #54
RC000E's Avatar
RC000E
Originally Posted by Evil-Twin
We tried to make this car idiot proof.. but as time has shown, there is a much higher order of idiot out there..
BTW the OLM algorithm string was changed in 2000.
The base line was increased from 10,000 miles to 15000 miles. The OLM was that good...
How smart do you have to be to read, Change the OIL when the OLM says too, or at one year, which ever comes first. Seems to me even an 8 year old could figure that one out.
Just for the idiots among us... when I said GM changed the OLM algorithms base line in 2000 to 15000 miles from 10,000 miles, that doesn't mean you can drive your car 15,000 miles between oil changes.... this car was so designed and the OLM updated to be idiot proof to insure a 200,000 mile motor. BTW the DOT compliance sticker on the door for tire pressure was put there because, these very same idiots were putting 65 psi in their tires because that's what it said on the sidewall. Max pressure 65 psi. They figure more must be better.
Premium fuel ( 93 Octane ), in Pennsylvania, where I live is 5 cents more than mid-range fuel . regular fuel is 15 cents cheaper than Mid range. Anyone who drives a Corvette, and is concerned about 4 dollars a fill, is driving the wrong car. Premium fuel is not always necessary but when your car need the extra octane at sea level or under load or in a lug load condition, its good to have it there...... every time the knock sensors are activated, that pre ignition explosion before top dead center is destroying your engine one molecule at a time. plus you are loosing any added performance value, and for what? 4 dollars? Seems pretty stupid to me.. but then stupidity breads those idiots we so lovingly talk about. Those are the guys you would not want to be the second owner of their car.
It's a shame when your opinion on the subject is in the vast minority. Apparently guys who read owners manuals know more about combustion science and internal engine mechanics than the engineers who built the car and guys who have built engines for decades. Interesting crowd of regurgitation.
Honda made it very clear why they, as a company, insured that higher compression engines allowed for survivability with lower octane fuels, and they said it very clearly in 2003....because Americans will put the wrong octane in the car, regardless how they are directed. You have to anticipate ridiculous behavior, in order to protect yourself from a warranty perspective. In 2004, the new civic si had over 30 ft/lbs of torque (at the tire) left in the tuning, to simply be sure the engines survived low octane. If you, as an owner, had your brain intact, you could re-tune the ecu to unlock a large boost of torque in the midrange.
All these guys here preach about how the car simply "detects" knock and adjusts, but they all avoid the subject of what is actually occurring internally to create a frequency to activate a knock sensor.
Old Apr 13, 2016 | 11:32 PM
  #55
Evil-Twin's Avatar
Evil-Twin
I was not going to get involved in this discussion any further.... but when compression causes detonation before ignition, two explosions occur before top dead center... the knock sensors detect this anomaly and instruct the pcm to retard the timing to prevent further detonation before top dead center, this reduces performance because the power stoke is compromised... You need to get you foot out of your mouth when you come here , and stop acting like you know something about this car... trolls are not welcome here... Some of us have been involved in automotive research and design for 40 years, and retired with a healthy paycheck, that indicates we actually do know something about this car... I won't entertain this silliness anymore but believe me, some of us are laughing... Thanks for the laughs... just another wanna be coming here to try to pretend to be something they are not.
Not all of us are as dumb as we look. I know I have had my hand in every single C5 on the planet and am proud of what we have accomplished in its design, and its continued heritage. So go back to the Honda forum, and troll over there.
Old Apr 15, 2016 | 12:47 AM
  #56
donald4972's Avatar
donald4972
St. Jude Donor '14-'15
If I were in the market for a used C5 (or C6,C7) Corvette, and I found out the previous owner put 'regular' fuel in it, I would not be interested any further, at any price!
Old Apr 15, 2016 | 08:45 AM
  #57
ronwc's Avatar
ronwc
To Regular Gas ok?
Old Apr 15, 2016 | 08:52 AM
  #58
captaineddie
Originally Posted by ronwc
Me too! It's too late to worry about what the previous owner did or didn't do. Put premium gas in the car from now on. I think Shell V Power might be a good choice.
Old Apr 15, 2016 | 02:26 PM
  #59
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Originally Posted by thisMSGgood4me
Since it hasn't been mentioned yet in this thread, I'll make one more point for using premium vs regular. While we all know premium is more expensive, all other things being equal, you will get a bit better gas economy (more mpg) with premium than with regular, besides getting better performance. So the extra cost for premium does in fact pay for itself to some degree by allowing you to get more miles out of a tankful. Thus paying extra for premium is not as bad as it seems.
Correct - the knock sensors retard timing if knock is "heard". You will get better mileage and performance with premium fuel. Long term - knock (better described as pre-detonation) is harmful.
Higher octane simply means that it burns at higher temperature reducing the possibility of knock.
Old Apr 15, 2016 | 02:52 PM
  #60
Carcrisis's Avatar
Carcrisis
I wouldn't skimp on the gasoline or the motor oil I'd use in a Corvette. The LS1 engine was designed to run on 91+ octane fuel, as mentioned earlier (comment # 13). Besides the engine will perform better, experience better fuel economy, and last longer with premium gasoline. This really is a no-brainer.
