Leak?
Old Apr 16, 2016 | 05:20 PM
craig_vette's Avatar
craig_vette
Default Leak?
After changing my oil for the first time today, I turned the car on for about 5 minutes to let the new oil cycle. When I walked to the back, I noticed this leak. Not sure if it's normal exhaust or condensation or whatever or if it's something serious. I didn't have the AC on in the car. I dabbed a paper towel over it and it's clear. Perhaps just condensation? Like I said, I only had the car running for 5 minutes.
Can y'all take a look?
Old Apr 16, 2016 | 05:41 PM
Vanover's Avatar
Vanover
https://www.youtube.com/watch?v=muCu7_Ownd8
Yep it's just vapor moisture,nothing to worry about.now go drive it and blow it out
Old Apr 16, 2016 | 05:43 PM
sloopdawg's Avatar
sloopdawg
That's what happens when you get the Vettes' juices flowing
Old Apr 16, 2016 | 05:47 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Old Apr 16, 2016 | 05:48 PM
craig_vette
Appreciate it. I figured it was a stupid newb question but better safe than sorry.
Old Apr 16, 2016 | 05:58 PM
craig_vette
Unrelated question (hate to start another thread about something easy). After I changed my oil, I tried to reset so that the DIC reads 100% oil life remaining. I went to the DIC, Trip button, found "Oil Life Remaining 42%" then held RESET button for two seconds. It beeped and displayed "_ _ _% oil life remaining" and it just stays there. It won't say "100%". What did I do wrong?
2000 FRC
Old Apr 16, 2016 | 06:40 PM
jimmyLSX's Avatar
jimmyLSX
2000 FRC
I believe you have to turn the key to run but not on then hold the reset for like 10-12 seconds then it should display 100%. unless 2000 corvette is different to a 2003 which I doubt.
Old Apr 16, 2016 | 10:10 PM
When your engine is running, the exhaust gasses pass through the cats and water vapor is one of the byproducts. What you are seeing is normal (water) that comes out of the weep hole in the muffler.
Old Apr 16, 2016 | 10:21 PM
Choreo's Avatar
Choreo
2000 FRC
Turn the key to the ON position (engine off) and press the accelerator to the floor 3 times - should reset to 100%
Old Apr 17, 2016 | 02:50 PM
SG Lou's Avatar
SG Lou
That's the way I do it....same procedure on my 03 Silverado
Old Apr 17, 2016 | 05:17 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
To Leak?
