While swapping out my starter on my 2001 C5, I accidentally yanked these wires out of their sockets on the plug. Anyone know how they go back in to their correct terminals?
Look carefully at the connector and see if you can find an A or a C near one of the wire ports. From the shop manual the dark blue and white goes in port A, yellow and black in B and light green in C.
Looking into the end that plugs into the mating connector ( black portion in your picture) and with the locking clip UP, A is on the right from what I can see in the manual.
That helps a lot...thanks. I looked up some images on google and that is what i'm seeing. gonna put it up for the night tho..
thank you again...I appreciate your help.
