dumb question on climate control
Thanks for any advice.
If you have a dual zone system and you have the MEMORY functions, you need to set the memory settings.
If you read the OWNERS MANUAL, it explains ALL the features that you can set to a MEMORY SETTING.
Unlock the car with your FOB-1
Set the:
Radio stations, volume, HVAC settings, seat position, HUD settings, ect to something that YOU DESIRE. If you set it to AC OFF, it should be off at start up.
Press and HOLD the MEM-1 memory setting until the little yellow light flashes. If you are the only one that drives your car, set the FOB-2 and MEM-2 to the SAME settings. Just incase you grab the wrong fob!
NOW, each time you unlock your car and get in and turn the ignition on, every memory function will return to what you set it to.
ALSO,, If you have a weak (old battery) when you cold crank the engine, battery voltage can drop low enough to cause the DEFAULT settings to return..
The A/C light doesn't mean A/C is active - just that A/C is possible.
It's really a very good system. Just leave it alone.
I always wait for the guage sweep to complete before starts and use restraint and move slowly when making HVAC adjustments...
