Tpms
Old Jul 6, 2016 | 10:25 PM
drtyTshrt's Avatar
drtyTshrt
Default Tpms
I have C6 wheels with TPMS in them on my C5.
The system does not recognize the signal.
I have to clear my DIC often.
I have the original tires and over the weekend I took the valves out of all the tires so I could cut the tires to get the original sensors out and swap when I get new tires soon.
The C5 tires were about three feet from the car over the week end and when I go to drive it Tuesday the check engine light is on and the DIC says RR Flat, RF Flat, active handling not operating.
I have not pulled the codes yet but does anyone think that the system has picked up the original sensors?
Old Jul 6, 2016 | 11:21 PM
73Corvette's Avatar
73Corvette
Sounds like it did... were they still working when you took them off the car?
Old Jul 6, 2016 | 11:27 PM
drtyTshrt's Avatar
drtyTshrt
Yes but they have been sitting about 12 feet away from the car for about 3 years now.
Old Jul 7, 2016 | 12:24 AM
Best to do it now than to have to break the tires down again to install new sensors.
Old Jul 7, 2016 | 09:10 AM
73Corvette's Avatar
73Corvette
I just answered your question with my opinion...It seems possible...
I did not suggest using OLD sensors BAD idea...
Old Jul 7, 2016 | 09:56 AM
drtyTshrt's Avatar
drtyTshrt
All four sensors are replying to the DIC, I hastily posted a short version last night.
My question was just to ask if it was possible for them to override the C6 sensors in the wheels on the car.
Can I get suggestions where to get new sensors and a good price?
I still need to pull codes for the check engine light. it was out when I started the car last night but came back on within 5 minutes.
Old Jul 7, 2016 | 11:25 AM
drtyTshrt's Avatar
drtyTshrt
I pulled the codes and had 5 BO RFA all were History no surprise.
The check engine
P0161H
P1416HC
Old Jul 7, 2016 | 05:31 PM
Rick369's Avatar
Rick369
I agree with buying 4 new sensors. Make sure you buy either original AC Delco or Schrader TPM sensors. Schrader is the manufacturer of the AC Delco TPM sensors. Do not buy aftermarket sensors.
Old Jul 7, 2016 | 08:13 PM
73Corvette's Avatar
73Corvette
Old Jul 7, 2016 | 08:37 PM
GUSTO14's Avatar
GUSTO14
If the old tires have been sitting undisturbed for the past few years, they went to sleep and did not cause any interference with your RFA.
When you took the valves out and cut holes in the tires over the weekend, you very likely "woke them up" and they transmitted zero air pressure to your RFA which gave you the message on your DIC.
Good luck... GUSTO
Old Jul 7, 2016 | 09:58 PM
drtyTshrt's Avatar
drtyTshrt
Good luck... GUSTO
That is the answer I have been waiting for.
To Tpms
