Back when my C-5 was fairly new, had maybe 200-2500 miles on it, I ran over some debris, and cut the LR tire, right where the tread meets the sidewall. The cut went right into the cords, tire was junk.
Thinking that with only 2500 miles on the car, I should be OK, so I only replaced the one tire. I was OK..............for a while. About 4-5000 miles later, I get out of the car at work, and smell hot gear oil.
Apparently, the two tires, although both Goodyear Eagle RFs, wore at different rates, and the two rears had become different enough in OD, that the posi unit was unhappy......
Just thought I'd toss this into the discussion.
100% ON THE MARK!
The more DIFFERENCE in tire diameter between one side than the other will make the differential limited slip clutches work overtime and accelerate the wear!
The C5 Differential limited slip unit isn't that rugged to begin with and putting different size tires due to wear will significantly SHORTEN it life and performance.
I had pretty new TOYO Proxis tires on my ZO6. Had approx. 3000 miles on the tires.. One tire had a non repairable puncture wound! There was enough wear that I had to replace both tires to be on the SAFE SIDE!
Looks like something similar to what happened to me wife. She ran over a bungee cord that was laying in the road. The hook bit into the tire, and blew it out. HOWEVER, it apparently stuck into the tire, for a while, and became a pinwheel, doing a real number on the quarter panel, before she got it stopped.....
You realize, that's both unsafe AND illegal, RIGHT?????
Lon
Ah,,,,,,,,,,,,,, Come on!! A little GORLILA GLUE ought of easily fixer that!!!!
Not sure there are any laws in the books about it but Tire shops that do it are taking a big risk.
The Tire Industry Association spokesman mentioned the case of Barber vs. Mossy Ford, in which an improperly repaired tire led to a fatal crash in 2006 and a $22 million court judgment. Barber vs. Mossy Ford raised the stakes for all future tire repair lawsuits, he said.
I try to look at things from a logical point of view and try to avoid knee jerk reactions and decisions based on emotion. Looking at the way a tires side wall is constructed, having a single puncture point (not a linear cut), would not logically cause enough damage to the side wall that could cause a blow out. While it is true that a few of the cords could be damaged and fail, the remaining cords would have enough structural strength to support the tire and car. Now, with that said, I am certainly open minded enough to consider any other ideas as long as they are based on facts and not emotion. Sort of like the whole "which oil is better" debate. I've never seen any research that shows engine damage as the result of dino vs synthetic oil. Likewise, I've never heard of anyone experiencing a sidewall blow out following the patching of a sidewall. So, the question is...are these simply scare tactics by tire dealers with profits in mind or is there any validity to this assumption. Show me the proof and I'll certainly change my way of thinking.
Most reputable tire shops will not patch sidewalls just as they will not patch run flats that have been driven flat for some distance. It is for liability reasons. The tire's structural integrity has been compromised.
