Touch-Up Paint Mistake
Old Jul 19, 2016 | 05:49 AM
chasboy's Avatar
chasboy
Oldtimer
Originally Posted by kobrak
bam, gone. Won't hurt the paint if you get it on and then off ASAP!
Except all you need is one mistake in handling that stuff and bam! You're repainting a body panel.
Old Jul 19, 2016 | 07:35 AM
strand rider's Avatar
strand rider
I am not a fan of power tools when there is no way back from a mistake. It's not like you are plowing the north forty acres . Of course, if you have the experience, the learning curve is behind you .
For myself I would be very disappointed if I learned my clear-coat, since I bought the car used, is not as expected and I learned something with my new power tool. With hand work, a rookie has a better chance . Ir's not like you're going to get all worn out working a paint chip.
I would suggest you simply trim the brush to match the work instead of using another method that might not control the paint as well. Pin stripers use a razor blade to custom shape every new brush. Often people will construct a paint brush made from a single eyelash , for fine detail painting . Unless you are a house painter, you might consider if the brush is optimized for best results, although I am a big fan of toothpicks as useful tools .
Obviously, this is not a big deal with such a small area, but when guys start blobing paint or looking for scraps as a paint carrier , there are other ways. Not always better, to be clear, but certainly not an inferior choice, if used correctly.
