Are oem rear decklid C5 emblems still available through the dealers? Anyone purchase a oem replacement through one of the forum vendors? Just noticed this weekend that the lower thin parts of the crossed flags below the oval have fallen off, all that remains is the black stick on tape.
I've bought a set from the stealership about a month ago. The rear was about 75$
The C5 emblems are available from a dealer as far as I know. Contact one of the forum vendors for pricing.
Originally Posted by canuck9
Vendor info?...do they make a front emblem as well?
All the best,
Michael
Sent you a PM on this. IIRC, the front emblem is straight and you need to bend it slightly to match the curve on the front fasica. The rear works perfectly. Not sure if they come with the double sided tape though.
I got a front emblem through Amazon a few weeks ago, it was in GM packaging and it did have the double sided tape
Edit : I also cut the oval off the old one before installing the new just to see what it looked like. I thought it looked pretty good but I couldn't bring myself to cutting up the new one
Reason: Picture
I searched their site, no go unless they named them something other than emblem. I really would like something other than plastic for the front. The rear is going to get removed sooner than later, the plastic is starting to degrade.
