Headers for Dummies help?
Old Sep 5, 2016 | 02:29 PM
mikeam's Avatar
mikeam
Default Headers for Dummies help?
Hi, I know nothing about headers so I need some guidance on what to order. To make things simple, lets just say I'm buying Kooks headers (the shop only sells Kooks which I have no problem with).
- 2000 C5 convertible (OO), 46K, 6spd with Magnaflow X-pipe and Corsa Pace car catback. X-pipe and Corsa will say on. I'm ONLY adding headers, NO Cam or cutouts.
- goal is to get more of a exhaust rumble, don't care about increase of HP.
Header questions:
-what size do order to match my existing exhaust? what's the difference between the pipe sizes (1 3/4 & 1 7/8)? Sound?
- Cats, can they use existing cats?
- coating, sounds like I want them coated, correct?
shop offers:
http://www.pcmofnc.com/product/1997-...ction-pipes-3/
thanks,
Mike
Old Sep 5, 2016 | 02:32 PM
buckeye1872's Avatar
buckeye1872
Old Sep 5, 2016 | 02:43 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Most headers come with a x-pipe with or without cats, mostly so they (manufacturers) can mate the headers to your cat-back exhaust. I ordered mine with high flow cats. Headers will give you more power, if you don't plan on any other mods you could go with smaller tubes. They will make your car sound much better, more of a tuned sound, you should also get a tune. Again if you are doing no other mods I would go with a mail order tune like from ECS.
http://www.eastcoastsupercharging.com
Old Sep 5, 2016 | 02:51 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Also part of a tune you can have fans coming on earlier, skip shift delete, 2 mph fuel shutoff, and other stuff I would discuss with Doug at ECS or whoever you choose ????
Old Sep 5, 2016 | 03:22 PM
midnight01's Avatar
midnight01
Header questions:
shop offers:
thanks,
Mike
With Kooks headers you will have to have a shop fabricate your existing midpipe, which means you will need 2 new cats. Also you might have a hard time getting them to not rattle on the heat shields because the Kooks headers extend a distance back and most people buy the kooks with the catted xpipe. Best bet is to buy the catted pipe with the headers so everything bolts right up and you dont pay extra for fitment.
Old Sep 6, 2016 | 12:22 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
I strongly suggest going with a matched set of headers and x-pipe/converters. You will be miles ahead as aforementioned in getting everything to fit up right. You can likely sell your used X-pipe/converters to someone in need here on the forum.
I have a 2000 as well, and went with Kooks 1 7/8 vs. the 1 3/4 as I might go forced induction one day. If you never have plans of super or turbo charging, just go with the 1 3/4 (smaller) set.
Full details of what I did to my 2000:
https://www.corvetteforum.com/forums...d-started.html
Take a look at my pictures and you will see why you want a matched setup. Axle-back exhausts are pretty much interchangeable; so this will work with yours.
Are you sure you just don't want to do cutouts instead? Then you can go loud when you want, and quiet when you want to sneak up on someone.
Old Sep 6, 2016 | 08:08 AM
mikeam's Avatar
mikeam
Thanks for all the information and recommendations! Much appreciated.
Old Sep 6, 2016 | 10:40 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
If you think you're going to be giving it a big bump in power one day (think forced induction) then go with the 1 7/8" headers. You may not maximize their capability while working with a bolt on or mild head/cam setup, but if you start going bigger displacement, or positive displacement, then they'll really shine.
The headers will make the car louder, but may not affect the sound as you might think or want. Cam is mainly going to be where you get that rumble sound from. That, and the Corsa's are pretty tame in sound when exhausts are concerned. A Magnaflow, LG Big 3 or Stainless Works, B&B, etc would give you a deeper rumble than the Corsa's, but you're going to sacrifice the best thing the Corsa gives you which is no drone.
Old Sep 6, 2016 | 11:31 AM
grantv's Avatar
grantv
Agree with above. Headers will give you a nicer sound, even a bit more volume (more under throttle, not much at idle), but nothing that much louder. If you're doing this for sound only, I'd buy different mufflers instead.
Old Sep 6, 2016 | 12:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The only thing that going to SIGNIFICANTLY increase the engines LOUD OUTPUT is higher compression and a different cam.
YES, headers will give you some additional performance noise but your mufflers will need to support in the noise department. Be careful that you introduce unwanted DRONE if you chose a different muffler...
YES, I highly recommend coated headers. They significantly reduce under the hood temps and will look better a LOT longer.
I also recommend getting the matching midpipe.
BC
Old Sep 6, 2016 | 01:02 PM
jhopper408's Avatar
jhopper408
The 1/750 are good up to 700 HP.
Old Sep 6, 2016 | 02:38 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I also recommend getting the matching midpipe.BC
Originally Posted by jhopper408
The 1 3/4 are good up to 700 HP.
I agree with the above. I added Kooks 1 3/4 long tube headers (ceramic coated) with Kooks matching x-pipe with hi-flow green cats and their mid pipes and they fit well and tucked under nicely after some adjusting. I went with the Kooks x-pipe with catted hi flow green cats so that the car wouldnt throw any codes or ned a tune at start up. They advertise that this is 95% not 100% guaranteed but my '99 did not throw any codes after I started it up after the installation. Still no codes 3 weeks later. The new Kooks headers are a breeze to install compared with any of the other brands. They slip in from undermeath without removing anything except the ground wire and no need to jack up the engine. You do have to remove the aternator and bracket to remove the driver side exhaust manifold. I suggest replacing belts while you have them removed. Takes about 5 1/2 hours with belt replacement.
Here is my thread about the install: https://www.corvetteforum.com/forums...rs-are-in.html
I have a lot more pictures of the installation if you need to see anything in particular.
Mike
Old Sep 6, 2016 | 03:30 PM
JEH03Vette's Avatar
JEH03Vette
Old Sep 6, 2016 | 04:28 PM
sbadd99's Avatar
sbadd99
I put in a set of ceramic coated OBX headers a few years ago, never had any issues with them and still don't at about 1/3 the cost.
To Headers for Dummies help?
