I have upgrade my 99 tpms to the 01-04 set up but while training the fob and tpms I can only get up to the fob. The fob trains just fine. However, I can't get passed the fob training to train the tpms. After I press the reset for 3 seconds, I get fob training,when I press the option button to move me to the tpms,it just stays on the fob. I've checked fuse 27 and it's ok.
wire to receiver connector are
blk/white to pin4, pin ope, pink to pin 2 and orange to pin1
I'm using a new connector.
I've seen this issue before but,I can't seem to find the tread on it.
Thanks for the link, It's what I had read when I was first researching this mod.
Same exact issues. Returning the receiver in the morning for a replacement.
No luck with the used replacement Receiver. still have the same issue. Reinstalled the 99 set up and all works as it suppose to. I think I'm going to purchase a new receiver rather than screw around with use crap! Unless someone has a suggestion.
