C5 ash tray area upgrades
Old Sep 13, 2016 | 10:00 PM
Den's Vet's Avatar
Den's Vet
Not meaning to jump this thread but how is everyone getting their HVAC to display .Mine is faint
Old Sep 13, 2016 | 10:11 PM
Sam Handwich's Avatar
Sam Handwich
use google to do a search. there are fixes here on the forum
Old Sep 13, 2016 | 10:17 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Here you go !!!
File Type: docx
Old Sep 13, 2016 | 10:28 PM
FX VETTE's Avatar
FX VETTE
wideband and meth controller... I'm thinking about running dual widebands so I might end up changing this but until then this is how it will stay
That is wicked cool!
Old Sep 14, 2016 | 12:01 AM
Fed Up's Avatar
Fed Up
"My Dad's a TV Repairman"
That's an interesting mod. Will you be keeping the door to the ashtray in place and will it be functional (that is, will it close over the GPS unit in order to conceal it)? Hope you post up pics of the install and the finished look.
Depending on how much I hack up the interior, the door can stay. The key is getting the USB hardwire to go straight down, so I figure a 5/16" hole drilled into the base will work. I'm still toying with the idea of pulling the door and making a color-matched bezel that still has a power port in it.
Old Sep 14, 2016 | 01:16 AM
Revolver ZSTi's Avatar
Revolver ZSTi
moved down the hvac to the ashtray area and made a custom nitrous switch panel
Old Sep 14, 2016 | 08:48 AM
runner140*'s Avatar
runner140*
Originally Posted by akapounder
Here you go !!!
Man, you really take the high road.....wish I did that more. I'll try.
Old Sep 14, 2016 | 09:51 AM
Dmiles2004's Avatar
Dmiles2004
Default Here's mine
My old iPod mini and an interface from DD Mods. I think it works. And it's hidden by the door.
Old Sep 14, 2016 | 11:01 AM
StingrayRebel's Avatar
StingrayRebel
Originally Posted by Revolver ZSTi
moved down the hvac to the ashtray area and made a custom nitrous switch panel.
I really like that... did someone make that panel for you or did you use a sheet of carbon fiber?... how difficult was it to make the climate control fit in that spot?
Old Sep 14, 2016 | 04:42 PM
DanSavage's Avatar
DanSavage
When I installed seat heaters in my `03 AE vert, I needed a place to put the switches. So, I pulled the ashtray, then designed a 3D printed switch plate that would fit into its place.
Here's a couple of pics of the switch plate installed and pulled out of the ashtray hole.
I've since repainted it from black to shale using match paint I bought online.
Old Sep 14, 2016 | 09:00 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Mine is a good switch panel. Not sure where I'm going to move it all to when I do a Double D triple gauge double din center bezel.
Old Sep 15, 2016 | 07:18 PM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
I put my seat heater controls where the lighter was and made a Carbon Fiber coated panel that fit the ashtray opening where I put my exhaust cutouts switch, my AL Laser Jammer control and a switch for my front camera.
Old Sep 15, 2016 | 08:21 PM
  #33
jrprich's Avatar
jrprich
In my 99 I installed a SAT Radio in that spot. Took a bit of work to get it mounted but it was still working after 70k. And yes, the door still functioned
Jim
Old Sep 15, 2016 | 08:22 PM
  #34
jrprich's Avatar
jrprich
I wish I could locate an LCD screen that would fit in there for a BU Camera........
Old Sep 15, 2016 | 08:30 PM
  #35
Pounder's Avatar
Pounder
1/4 mile/AutoX
There is a ton of choices out there !!!
https://www.amazon.com/BW-3-5-Inch-M...ll+lcd+display
Old Sep 15, 2016 | 08:39 PM
  #36
FX VETTE's Avatar
FX VETTE
Nicely done!
Old Sep 15, 2016 | 09:12 PM
  #37
jrprich's Avatar
jrprich
Only 2.5" of vertical space available in there............
Old Sep 15, 2016 | 09:42 PM
  #38
Pounder's Avatar
Pounder
1/4 mile/AutoX
that was just one choice, I'm not doing everything for you ???
Old Sep 16, 2016 | 01:47 AM
  #39
Revolver ZSTi
nah i made that custom panel my self, the carbon fiber sheet my friend made,
it actually fits rather well, just got to trim stuff down with dremel and find ways to keep it tucked up, took me a 1 hour because i took my time
