Battery symptoms
Also, what is the typical current output of the alternator if the battery is charged. I want to check it.
https://www.corvetteforum.com/forums...e-reading.html
https://www.corvetteforum.com/forums...tion-long.html
https://www.corvetteforum.com/forums...nd-issues.html
Do not, do not, DO NOT, use your current C5 alternator as a core. Most of the remanned and aftermarket "C5 alternators" are actually generic GM crossover parts and thus they do not have the duty cycle function for the PCM. Installation will cause all sorts of electrical issues.
If it turns out to be an alternator issue, either have yours rebuilt or, if you are buying one, make sure the seller knows it's a C5 alternator, not that "it'll work on a C5."
That's why we are WARNING YOU!
More times than not,,, you will get the WRONG ONE! TRUST US!
They look exactly alike but only the GM LS1/6 C5 alternator will work properly!
BC
They can also properly test the alternator output voltage and charging current. They need to vary the duty cycle to insure that its able to meet the charging system demands.
Bill
