Something wrong with friends vette
Old Nov 6, 2016 | 01:03 AM
Jarame g's Avatar
Jarame g
Default Something wrong with friends vette
My friend was almost red line in third gear and missed 4th and put in second.. A big flame came out of Exhuast then the car bogged down didn't want to start then finnaly started but it runs like something flooded no check light come on no oil anywhere it tried to idle up to normal then went back to not running good could it filed the plugs or something or blow something or maybe bent a valve any ideas would be apriciated
Old Nov 6, 2016 | 01:39 AM
Well, I do not believe there is an over-rev protection when downshifting, only for upshifting. You might want to see if any codes have been set on the DIC and post them up if there is.
Otherwise, someone who has more knowledge of these cars than I do will hopefully post up and give some more advice.
Old Nov 6, 2016 | 01:46 AM
Jarame g's Avatar
Jarame g
I don't think any codes are thrown my friend said it may be the spark plugs but we don't know 3rd hear was almost pagged out and he threw into 2nd thinking it was 4th it revved up and braked down there was a big flame that came out of the driver side pipe then it runs like u have it in 5th gear trying to take off, I researched that it could have messed with the timing or possibly bent a valve , it would still drive but it would barley go.
Old Nov 6, 2016 | 03:34 AM
Carl Timonen's Avatar
Carl Timonen
First thing I'd do is to take off the valve cover and do a visual inspection. Check for any looseness, broke springs or anything else out of the ordinary.
Old Nov 6, 2016 | 06:12 AM
SaxyVette's Avatar
SaxyVette
ouch, a missed shift.. makes me glad I'm driving an A4..I'm wishing your "friend" well. Let us know what you find on his car.
Old Nov 6, 2016 | 08:00 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Floated a valve, hit the piston ?? not good, above suggestion start with the valve cover or compression ck.
Old Nov 6, 2016 | 10:03 AM
c4cruiser's Avatar
c4cruiser
Run a compression check on all of the cylinders. Hopefully it wasn't a valve bending or braking off and maybe have put a hole in a piston.
If there is an AutoZone store nearby, they will have compression tester for rent. You put down a deposit and when you bring it back in good condition, you get the deposit back.
Good luck!!
Old Nov 6, 2016 | 10:07 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Pull the pushrods. Roll each one across a flat surface like a large mirror. Most likely one is bent. They usually bend before valves do so that's where you start looking. Easy to change too.
This is exactly why I always say use stock pushrods with big cams. They are a weak link and should be left in place instead of hardened rods.
Old Nov 6, 2016 | 07:41 PM
o2bnkc's Avatar
o2bnkc
That's what I was thinking.
Old Nov 6, 2016 | 07:53 PM
Arthur6's Avatar
Arthur6
If he was running octane booster there's a good change he blew one of the heads.
Old Nov 6, 2016 | 08:06 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
PTV and Bent a valve/pushrod most likely.
Old Nov 6, 2016 | 08:08 PM
v8srfun's Avatar
v8srfun
Please explain whi octane booster would cause a blown head.
To Something wrong with friends vette
