Flood won't start
Old Nov 29, 2016 | 06:55 PM
Godspeed928's Avatar
Godspeed928
3rd Gear
Default Flood won't start
We had a recent rain storm here, unexpected amount of rain
The rain came up and into my 02 ls1 when I went
To start it, it clicked as if the battery was low, so I put the battery
Charger on it and started right up, I noticed the gauges went crazy
So I shut it off, when I went to start it up again it won't start.
The lights come on wipers everything works, it just won't crank???
Any ideas?
Old Nov 29, 2016 | 07:47 PM
az57chevy's Avatar
az57chevy
How high did it get to? Suspect some wiring is corroded. Can you push into sunlight during the days to help dry it out? Or if in a garage use some heaters to dry it out? The quicker you can dry it out the better. If the flood reached your 'puters you might pay extra attention there to dry it out
Old Dec 1, 2016 | 05:41 PM
kg54trains's Avatar
kg54trains
Any ideas?
Water and Corvettes do not mix well... Check levels in side car to see how high it was insided the car.. That will also help give you how high it was outside the car.. Codes can help but you may want to think about finding a Good Corvette Mechanic, not the dealership ones, as a fall back
Old Dec 1, 2016 | 09:56 PM
Godspeed928
3rd Gear
Default Flooding
The water went up and inside the car about 2"
Got a guy coming to check it out, when I turn the key on the fuel pump comes on, just won't crank
Old Dec 2, 2016 | 08:42 AM
ersatz928's Avatar
ersatz928
Sounds like your BCM, fuse box , and relays in the passenger footwell got wet......dry out your BCM, replace the relays, and you should be good to go. Well, also check your starter....it probably got submerged too.
Old Dec 2, 2016 | 02:02 PM
Godspeed928
3rd Gear
Thanks allot to everyone
I am new to forums but everyone
Has been really great.
I am waiting for a corvette guy
I'll keep you guys filled in
To Flood won't start
