TPMS Issues
Old Dec 5, 2016 | 10:36 AM
Brit dex's Avatar
Brit dex
Default TPMS Issues
Hi all
never had these on the car since buying it.. had a set with it.. which were old and corroded etc.. tried them a few weeks back on the reset.. no Joy..
so bought a set of brand new AC Delco ones from Rock Auto.. fresh out the bag.. Tire Training mode.. big magnet..... nothing :-(
Am I missing something??
Old Dec 5, 2016 | 11:02 AM
jackthelad's Avatar
jackthelad
There were two non-compatible types depending on year. 2001 on has a different operating frequency. Sure you got the right ones?
BTW, does the key fob work? It uses the same receiver in the car, so if it is working, the receiver is good.
Old Dec 5, 2016 | 11:08 AM
Brit dex's Avatar
Brit dex
Hi Jack,
yes got key fobs that work and trained OK..
the TPMS devices I believe are correct .. I will double check..... but I bought under 1999 year drop down menu.. which is my car year..
GM 20807214
Key fob is 19299230
Old Dec 5, 2016 | 11:37 AM
jackthelad's Avatar
jackthelad
I believe OEM early sensors were by Schrader - at least that's what Tire Rack sold me when I got new ones for my '98, and they trained OK.
Totally confused now as I looked on GMpartsdirect, and they do quote part numbers for early and late sensors, but neither of them match the number you quoted.
I would check with Cultrag to confirm part numbers - GMpartsdirect quotes 25981210 and others quote 20807214 for early C5's.
Old Dec 5, 2016 | 11:47 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
If you have the correct sensors and they are mounted on your wheels, take the car out for a spirited 5-mile drive to "wake them up" and then try the magnet programming method. That worked for me when I installed my aftermarket wheels.
Old Dec 5, 2016 | 11:54 AM
Brit dex's Avatar
Brit dex
hi , I haven't mounted them yet, thought I would try and make sure they 'talked' before going to expense of mounting in the tires?
Old Dec 5, 2016 | 12:36 PM
MSG C5's Avatar
MSG C5
It's weird because when I originally mounted my new wheels, I could not get the new sensors to chirp during the DIC programming. I then ran a quick errand and I thought I would try again and all four chirped through the programming during the first attempt. Same magnet, same process. Not sure why, but the drive woke them up. Not sure what the best action is if the sensors are still outside the car. Perhaps the car needs to wake up. Maybe take a drive with the sensors sitting on the passenger seat.
Old Dec 5, 2016 | 12:51 PM
Brit dex's Avatar
Brit dex
thanks all....
further complication I'm in UK and my Car is a Saudi Car... so there is the thing of whether it is Euro or US spec... believe it is US spec... this could be why they weren't installed when I got the car!! :-)
it also has this weird thing of saying I'm 'over speed' on DIC when I hit 74MPH and you can't clear it..
Brit dex's Avatar
Brit dex
thanks all....
Old Dec 5, 2016 | 03:10 PM
jackthelad's Avatar
jackthelad
thanks all....
Given the car's "lineage", it MAY be that TPMS is not enabled, like in the C5 Z06's here - all US spec coupes and convertibles had runflats and TPMS enabled.
There's a ref here:
https://www.corvetteforum.com/forums...d-warning.html
which may be useful - discussion about a Dubai car with an overspeed warning. Google throws up lots of hits - including you of course!
My assumption would be that because of it's original owner, it has the overspeed warning and TPMS is off. Need a dealer with a TechII to find out.
Old Dec 5, 2016 | 04:44 PM
Brit dex's Avatar
Brit dex
great info thanks... yes been trying to find out...
not that I ever travel at 74mph you understand cough cough!!! :-)
Old Dec 5, 2016 | 10:09 PM
jackthelad's Avatar
jackthelad
Sounds disturbingly like a 120 kph warning. At least it's not Japanese spec, where the warning chime goes off continually if you exceed the limit.
Old Dec 6, 2016 | 06:42 AM
Brit dex's Avatar
Brit dex
Yes very true.. No ongoing chime.. But it does block DIC and can't be cleared
To TPMS Issues
