Racedeck Flooring
Old Dec 7, 2016 | 02:55 AM
Jistari's Avatar
Jistari
Nope.....clean....looks good
Old Dec 7, 2016 | 02:36 PM
BlackandTan2004's Avatar
BlackandTan2004
Originally Posted by Black 02
Looks great, nice job on the install. How thick is it and what does the transition to concrete look like at the end of the garage?
I have the transition pieces, I'll get some pictures tonight. 1/2" thick. It seems pretty durable, I beat the hell out of a couple of the cut pieces and there was no deformation.
Originally Posted by zipity
I have had my garage done for over ten years now and it still looks great. I give it a good cleaning twice a year and the rain and snow just melts and drains away as the underside has accommodations for drainage.
I even installed a four post lift on right on top of the tiles, drilled right through the tiles into the concrete.
What do you use to clean? I was thinking about using some simple green and a mop!
Originally Posted by Mickeyrx70
The garage looks fantastic! It's a perfect home for your gorgeous Corvette.
Thanks!!! It really does look killer! My neighbors love it and so do a few buddies that have seen it!
Originally Posted by 6speedsteve
I have the Diamond Alloy in my garage, purchased from Racedeck at the Goodguys Nationals in Columbus Ohio, it was discounted 25%, was shipped free & the transition pieces were also free with the purchase.
Only issue I have is my Nitto Invo's leave marks on the floor due to the soft compound of the tires.
Any pics of yours?
Old Dec 8, 2016 | 12:50 AM
6speedsteve's Avatar
6speedsteve
Originally Posted by Pounder
your not supposed to do burnouts on it !!
I always back my car in & I once let the clutch out a little too quickly & the floor was only partially done on one side of the garage & the floor slid out from under the tire & jammed itself under the garage door tracks, had to remove the track & use a prybar & block of wood to slide floor back in place.
Old Dec 8, 2016 | 01:23 AM
6speedsteve
Originally Posted by BlackandTan2004
Any pics of yours?
Only picture I have I took at night time, Chevelle wasn't able to be moved out of the garage so had to work around it.
Just keeping it simple, gray floor, white panels on side walls, black & white checkerboard floor tile on back wall, black trim, black cork ceiling, & LED lighting, & some brushed stainless panels behind my radiant heater on the wall & ceiling to match my toolbox.
Old Dec 11, 2016 | 03:53 PM
BlackandTan2004
Looks nice Steve! Is the Chevelle still a work in process?
Some pics of the transition pieces for Black 02
Old Dec 12, 2016 | 05:33 PM
novasscnc's Avatar
novasscnc
I used black and white vc tile, cheap and durable
Old Dec 12, 2016 | 06:01 PM
6speedsteve
Yes it is for a long time, I purchased it in 1992 & started working on it in Nov 1996, It is a 300 Deluxe Sport Coupe that is a mix of old & new.
Old Dec 12, 2016 | 07:01 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
That looks really good
Old Dec 12, 2016 | 10:44 PM
MeHeartCorvettes's Avatar
MeHeartCorvettes
Did my earlier this year. Really happy with the outcome!
Old Dec 13, 2016 | 08:47 AM
BlackandTan2004
What's VC tile?
Old Dec 13, 2016 | 08:48 AM
BlackandTan2004
Awesome! Love the red C7.... every time I see one I keep thinking I should get one....
Old Dec 13, 2016 | 08:59 AM
f6john's Avatar
f6john
What's VC tile?
Vinyl Composition. Seen alot in schools, hospitals, ect.
Old Dec 13, 2016 | 11:36 AM
  #33
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Looks awesome...where did you get it? How does cost compare to Race Deck?
