Enlightenment
Old Dec 13, 2016 | 03:48 PM
hclaeson's Avatar
hclaeson
Default Enlightenment
I own a C4 but looking to buy a C5. I would like some info on the C5 as far as what problems I may run into and what was the best years for this model. Thanks in advance for any input.
Old Dec 13, 2016 | 04:10 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
The C 5 is light years ahead of the C 4 in many areas. What year is a very hot topic here, and I would suggest reading all the Stickies in the Tech section. I love my 99 Coupe !!
Old Dec 13, 2016 | 04:11 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I was too slow, 8vette7 got me !!
Old Dec 13, 2016 | 04:16 PM
Z.youngg85@gmail.com's Avatar
Just went through the same search process.
You cant go wrong with a clean 2002 to 2004 c5 z06. Just check for the valvespring recall.
Old Dec 13, 2016 | 04:48 PM
hclaeson's Avatar
hclaeson
I am considering a 2002, 1 owner, 36k miles. priced at 16,990. It appears to be a stock coupe. Worried because if I buy a money pit the bride will bury me.
Old Dec 13, 2016 | 05:17 PM
David Shiel's Avatar
David Shiel
Default Well, we're
gettin' old and slooooowin' down! Some of us anyway!
Dave
Old Dec 13, 2016 | 05:23 PM
bikeriderga's Avatar
bikeriderga
With 36K and regular maintenance, you should not have any major issues.
The biggest issues with these cars are electrical. Most of this is due to moisture, corrosion, and rust. If that car was garaged kept and had all regular maintenance applied (plus a clean car fax), it should last you well up to 150,000 -200,000 miles with regular maintenance items to be taken into account (oil, tires, gas, clutch at around 75K, brakes, etc.).
One more thing. You may want to look at replacing the following (since they go at about 70K miles in my experience). Not right away, since you should be OK until about 60 K.
1. Hidden headlamp gears (swap the plastic junk for metal ones).
2. HVAC lighting (mostly due to weak soldering points). Do a lookup on this forum. Several people tell you how to make it better on the cheap.
3. A/C actuators : These are located in the door and behind the dash. There are two in the dash and one each in the doors.
Other than this and making sure all the grounding straps are clean and have some electrical lube applied, you should be good to go.
Of course do the column lock by-pass if that has not been done previously.
Old Dec 13, 2016 | 05:33 PM
The stickies and some time spent with the search function will be time well spent. Of course, questions are always welcomed.
Old Dec 13, 2016 | 06:39 PM
Vanover's Avatar
Vanover
Do your homework as 8vette7 said.there are a lot of cars forsale don't settle on one,get want you want its a toy not a need.
Old Dec 13, 2016 | 06:43 PM
IMXCITD's Avatar
IMXCITD
Spend a lot of time here researching. You will learn a lot. Make sure you test drive a few C5's and make a plan for finding what you like. You will really enjoy a C5. Many of us came from C4's and have had other vettes and still love our C5's.
To Enlightenment
