D585 coils
Old Jan 20, 2017 | 09:46 PM
lilryan's Avatar
lilryan
Default D585 coils
Got a good deal on a set of these coils so I picked them up. Passenger side took 10min to install. Driver side is still not together. The fuel line going to the rail is in the way. I see people tweak them a bit and it seems to work fine, but I haven't seen seen any pics of the coils on a c5. Anyone have any experience with them? I do think theyou look better and are supposed to produce a little stronger spark.
Old Jan 21, 2017 | 08:24 AM
StingrayRebel's Avatar
StingrayRebel
you can get some -an adapters and make a new fuel line if you would be able to route it around the coils... I have the same coils but mine are hidden behind the fenders, also make sure to have the tune adjusted for them... the dwell time is different for those coils than the stock ones, I believe they can just copy the dwell table from an older truck but check with your tuner first
