passanger airbag
Does anyone have any picture of removed passanger airbag with the dash mounted back in?
i could not find anything with help of google
thank you
If you're removing the air bag for motorsports purpose you'll need to replace the passenger side belt also (which is usually done anyway). There were two types of passenger belts used in C5s. Earlier belts up until I believe 2001 utilized a single function in conjunction with the SRS since you couldn't deactivate the air bag on earlier C5s. Eventually with the introduction of the cut off switch a dual function belt was installed. The car should not be driven with the stock belts without an air bag.
